Problems with Radiator swap 1988
Old Jun 5, 2012 | 11:38 AM
Qgregg's Avatar
Default Problems with Radiator swap 1988
Well it seems as if they changed the fittings on the radiator somewhere in 1988. was 1/4 inch slip on to 3/8 inch hose compression screw on. In my car i had the screw on fittings, rad went south so i purchased a good one 40,000 mi on it. Cut the hoses and used hose clamps to rad. (too much pressure) Struggling on what to do any suggestions.
Old Jun 5, 2012 | 12:01 PM
Doug's Avatar
Hmmmm. I've "hose clamped" trans cooler hoses a few times over the years without any problems from too much pressure.
Not sure of your exact arrangement but if you've simply clamped the hoses to a cut-off stub of pipe you might need double clamps or, better yet, some fittings with a rolled bead (or barbs) to hold the hose.
Old Jun 5, 2012 | 12:15 PM
Qgregg's Avatar
Doug thanks, maybe the double clamping will work.
Old Jun 6, 2012 | 01:47 AM
Greg in France's Avatar
If it does not, check for a blockage in the rad cooler.
Greg
mbergen
Oct 23, 2019 10:26 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
sogood
Sep 15, 2015 07:35 AM
obwoodie
Sep 3, 2015 07:45 PM
