radio install questions
Old Oct 12, 2022 | 03:41 PM
mike_D's Avatar
Default radio install questions
I am looking to replace the original cassette radio with this aftermarket unit,
I do not want to cut the car's radio wiring harness, so it would be easy to put the original radio back if needed. Here are my questions:
  1. Is there a wiring harness available to plugs into the car harness that I can wire to this radio ?
  2. the new radio needs to have access to the reverse lights circuit to be able to activate the backup camera function, how do I connect to that ?
Thanks for the help !
Pioneer AVH-3500NEX 1-Din 7-Inch Flip Out AV Receiver
Old Oct 12, 2022 | 03:46 PM
ptjs1's Avatar
Mike,
You haven't said what XJS you have? The radio wiring on very early cars is different.
However, if you've got a later XJS, it's very easy to find a wiring adapter. Just google "Jaguar XJS radio ISO wiring adapter" or similar. You'll find a simple plug adapter for about $5 on eBay which means you can keep your existing wiring.
Paul
Old Oct 12, 2022 | 03:54 PM
mike_D's Avatar
Paul,
Thanks. I have a 1990 XJS.
I'll check ebay now.
Mike
Old Oct 12, 2022 | 04:22 PM
mike_D's Avatar
I see lot of options for newer years, but none for 1990 or earlier. i'll keep looking, any suggestions ?
Old Oct 12, 2022 | 04:27 PM
ptjs1's Avatar
Also, I think a number of people have been unable to install those flip screen units as it fouls against other parts of the dash, when you try an open the screen I would seriously look at whether it can fit in an XJS.
Paul
Old Oct 12, 2022 | 04:45 PM
mike_D's Avatar
you bring up a good point. The car is with the mechanic currently. I get it back next week. I'll check the clearance of the flip out screen to see if would actually fit.
Old Oct 13, 2022 | 12:28 AM
Greg in France's Avatar
Mike
Assuming your car is a pre-facelift, the reverse light switch is activated mechanically by the gearlever. If you remove the console you will see a smallish cannister-like thing on the LHS of the lever with a sprung bal-end that is pushed in by the lever whennit isnin reverse. The cannister is adjusted by two threaded nuts so it engages properly. You just take a feed of the output side of the switch.
Old Oct 13, 2022 | 06:51 AM
Mkii250's Avatar
Anyone try the Blaupunkt Bremen? Old looks, new gubbins.
https://www.crutchfield.com/S-U1q8G5...QR-46-DAB.html
Old Oct 13, 2022 | 07:31 AM
Vee's Avatar
Vee
deleted
Old Oct 13, 2022 | 09:05 AM
Rescue119's Avatar
Paul
this is correct. ive looked into this and a single din with a full touch screen face is the way to go.
Old Oct 13, 2022 | 10:30 AM
mike_D's Avatar
can you suggest any specific models ?
also, any luck with a wiring harness ? I cannot find one for a 1990 XJS.
Old Oct 13, 2022 | 10:40 AM
Rescue119's Avatar
in my experience in installing radio systems I tend to hard wire directly into the factory harness. it takes longer to do but I never plan on going back to stock harness. and most people now want blue tooth for android auto / apple car play so retaining stock harness isn't a concern.
however in doing this you should leave a few inches of wiring from the stock plugs so if you want to return to stock radio its an easy to go back.
Old Oct 13, 2022 | 11:44 AM
mike_D's Avatar
I see this video of the flip out unit installed in an XJS.
is the clearance the same in my 1990 as in this one ?
Old Oct 13, 2022 | 01:33 PM
Vee's Avatar
Vee
No way that the screen can open/close with the transmission stick in park. There will not be enough clearance. If you need AC control access, good luck. I happen to have a trip computer, and that would be rendered useless by this screen....it is nice though.
The Blaupunkt seems like a cheap, poorly designed radio. The reviews have some consistent issues with bluetooth memory/selectivity, sound setting memory getting deleted, and other problems. For a $400+ radio, I would look elsewhere.
Old Oct 13, 2022 | 02:07 PM
ptjs1's Avatar
A number of fitments by owners seem to show that you can't mount it flush and have to have it sticking out from the standard recess which looks rather messy. In that video of the Pioneer unit, it doesn't seem to be mounted flush? Also concerns about the angle of the screen, unless you mount the unit further forward.. And it will cover the trip computer when in use. Not sure about whether it might have clearance to open when in Park. See these threads:
https://www.jaguarforums.com/forum/x...al-fit-163470/
https://www.jaguarforums.com/forum/x...ndering-91652/
I'd really want to see a nice flush-mounted installation using the standard mounting brackets before I'd consider one.
As regards an ISO plug, see whether the pic of a PC2-66-4 from Autoleads is the correct plug for your 1990? I've got one of those fitted in my 1994.75
Paul
Old Oct 13, 2022 | 02:41 PM
mike_D's Avatar
Paul,
I totally agree. for this to be considered it has to:
  1. be a flush, clean mount. sticking out like those from the other thread look bad (to me).
  2. be able to open to a vertical, viewable angle and clear the shifter in park.
Once I get my car back I will do some measurements, but I am extremely doubtful. I'll also email the installed from the video and ask if that was flush mounted or if they used some needed spacer that push the unit out enough to function.
Old Oct 18, 2022 | 03:41 PM
mike_D's Avatar
OK, I looked at the car and did some basic measurements. the video scree would not be able to open while that car is in park. It needs 6.25" and from what I see i'd only get about 5.25" a full inch short.
Old Oct 20, 2022 | 07:28 AM
stone4140's Avatar
I've been going through the same process. I'm considering a touchscreen, but one that does not flip up. It's adjustable, but my only concern is how far it will stick out. The nice part of the one linked below is, I don't believe it will interfere with access to anything above the receiver. It gets good reviews and it's on sale. I usually wouldn't consider Boss, but it seems solid.
​​​​​​https://www.crutchfield.com/p_104BE7....html?tp=72430
Old Oct 20, 2022 | 10:44 AM
mike_D's Avatar
I was a little bummed that the Pioneer flip up won't fit well. The Boss you found is a good compromise and for the price you can't beat it. I like that it has apple Car play. If you do install it, send pictures.
Old Oct 29, 2022 | 12:57 AM
jessquirl's Avatar
You can't put it in neutral when you turn the radio off?
