Rear hub axle removal
Old Jul 24, 2022 | 03:31 PM
lt1-xjs's Avatar
Default Rear hub axle removal
I just replaced my half shaft u-joints and rebuilt the rear hubs on my '89 XJS coupe. I researched and watched all the horrifying videos prior to disassembly knowing the splines were Loctited. I found a puller that works like the Churchill. Credit goes to JeffR1 from a post in 2013. He used the OTC 6574 puller with the plate. The hole has to be opened to 2.910" to fit the hub. A modified hydraulic coupler was used as the shaft protector/center and a good rust penetrant a must. It came apart fairly easy but required a 2' breaker bar all the way out.
You can tell the Kroil creeped through the splines.
The ultimate penetrating oil, 10 years old and a 1/2 can left.
Thorsen
Jan 10, 2022 06:57 AM
iownme
Oct 20, 2021 02:37 PM
StuG
23
Mar 26, 2020 03:46 PM
Ponysnake
Aug 12, 2019 07:21 AM
PaleRider
Jan 12, 2015 12:10 PM
