Replacing Intake Manifold Gasket-What else??
Old Aug 15, 2015 | 04:32 PM
Vee's Avatar
Vee
Default Replacing Intake Manifold Gasket-What else??
I have an AJ16 engine. What else should be replaced while the intake manifold gasket is getting replaced? Is there anything else that requires the manifold to come off to be replaced while it out?
Thanks!
Old Aug 16, 2015 | 01:58 AM
Greg in France's Avatar
VEe
Replace the short slightly S Shaped by hose underneath the manifold with the best quality one you can find.
Greg
Old Aug 16, 2015 | 04:47 AM
ptjs1's Avatar
Vee,
I would change the water rail pipe as it's a pain to get to otherwise and it's block connection does leak. Also, just because it's easier at the time, also check the heater valve and it's inlet and outlet hoses. I'm just about to replace my heater valve (which only leaks when it's turned off).
Good luck
Paul
Old Aug 16, 2015 | 09:18 AM
Vee's Avatar
Vee
Thank you both, that helps a lot.
toronadomike
Jan 22, 2026 10:13 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
cissdm
May 3, 2016 06:02 AM
rachelstr
Sep 3, 2015 12:59 PM
TC Johnson
Sep 2, 2015 09:30 AM
