Rim colour?
Old Oct 27, 2020 | 11:37 PM
VancouverXJ6's Avatar
Default Rim colour?
Out of curiosity what is the rim colour supposed to be? It certainly isn't gangster chrome, I tried scanning mine on a polished section with a phone App..no luck.
mine are tarnished and seem to be shedding their coating in spots? I want to plasti-dip them in the appropriate silver-ish colour.
For those unaware plastidip is a removable plastic skin paint you peel it off after if your done with it, can be great to 'see' what your car is like with black trim etc or to reskin faded rubber and painted surfaces temporarily.
Old Oct 27, 2020 | 11:45 PM
Jagboi64's Avatar
Autoglym's "wheel silver" paint is an almost perfect match. Comes in a spray can. If I recall there is a distributor in the Lower Mainland.
Old Oct 28, 2020 | 06:33 AM
petemohr's Avatar
Originally Posted by VancouverXJ6
Out of curiosity what is the rim colour supposed to be? It certainly isn't gangster chrome,.
It also isn't supposed to be PlastiDip!
I have "Dipped" a number of things but wouldn't attempt it on lattice wheels. There's no way you could get even coverage and trying to remove it would a nightmare. Stick with the Autoglym.
Old Oct 28, 2020 | 02:00 PM
Robbo D's Avatar
Here’s mine. Striped, etch primed, primed, top coated with a wheel silver paint and the lacquered. I kept the outside of the rim polished aluminium as I like the style. Easy job to do over a few days.
Rob.
Masked and primed.
Silver top coat.
Lacquered.
Finished wheel with new tyre fitted
Old Oct 28, 2020 | 06:27 PM
I cant remove the rims it would have to be done in place.
What was the exact product you used? Etched Im assuming is scratched up abit to get the paint to stick? Like 800grit?
Old Oct 28, 2020 | 06:39 PM
Jagboi64's Avatar
Etch primer often has phosphoric acid to promote adhesion, and some have zinc for corrosion inhibition on steel. It's a primer designed to go over bare metal and promote adhesion between the metal and the primers and finial colour coats on top. Sometimes it's also called Vinyl Wash primer.
Old Oct 28, 2020 | 06:42 PM
Learn new things every day.
do you think this is doable in place assumimg I use a liberal amount of masking tapes and plastic sheeting?
Old Oct 28, 2020 | 06:46 PM
Jagboi64's Avatar
I don't think it would be advisable to do it in place, as there will always be a masking edge somewhere near the bead of the tire. That's a place where it's difficult to prepare the surface,and the masking line is always a place where the paint will want to peel at the edge. It would be better to take the tire off and then the paint completely coats the rim and there isn't an edge to lift.
It will probably work short term to mask and paint in place, but I would expect the paint to start peeling or flanking off sooner than if the tire was removed and the whole rim painted as one.
Old Nov 3, 2020 | 10:23 AM
Rescue119's Avatar
If you are attempting this and are leaving the tire on buy a deck of cards and slide them between the rim/tire as a mask. Have done this on a few tires. Works great.
Old Nov 3, 2020 | 10:35 AM
BradsCat's Avatar
I always liked the lattice style wheels. I've seen them in silver, black, gold, and even red IIRC. I have a set from a parts car it anyone wants to try refurbishing them. They need to be cleaned. $50 takes all four.
Old Nov 3, 2020 | 10:36 AM
Rescue119's Avatar
I love that I got the lattice wheels.just wish they were 16 or 17 instead of 15
Old Nov 3, 2020 | 05:08 PM
BradsCat's Avatar
I thought they were 16"
Old Nov 3, 2020 | 06:15 PM
Rescue119's Avatar
As far as I know and have just 15s. The 5 spoke did 15 and 16s i think
Coreystrickland2nd
Jul 18, 2017 09:34 AM
Freddy Stroman
Jun 6, 2017 03:15 PM
jag302
May 16, 2015 10:41 AM
rjs5689
Jun 25, 2014 07:57 AM
byrd281
Jan 4, 2013 12:03 AM
