running temps
Old Mar 29, 2013 | 12:46 AM
smgdata's Avatar
Default running temps
So i put in a mechanical temp gauge in the car, i used the back right
vacuum switch, removed it and the temp gauge works great i got tired of mine on the dash all working when it wants to after trying to fix it anyways. now i can see the temp at all times, i know in gonna get ppl sayin its only really A bank but over all i think i can tell if it was overheating on the other side.
My question is what are good running temps on the freeway im noticing around 168F-180F then at a stand still it looks like it gets to around 190+F give or take a little higher if its hot outside.
Old Mar 29, 2013 | 12:56 AM
Sarc's Avatar
Hi Shawn
I think those temps are fine. I am running around 195 to 200.
I've came to the conclusion that maybe the absolute temp is not so important (within reason) The key thing is whether the temp is stable or not, or whether it creeps and creeps up
Old Mar 29, 2013 | 02:28 AM
smgdata's Avatar
True true.
Im not Creeping yet Will you be bringing your XJS next weekend?
Old Mar 29, 2013 | 11:09 AM
Sarc's Avatar
Probably not :-( It's in the shop. Failing SMOG. It's running too rich on both banks and there's no adjustment possible on that system. Current angle of attack is new fuel injectors. Unfortunately I bought a set myself from partstrain and they were rubbish. 3 didn't work at all, and 1 was stuck open. So we're looking for a better set now. :-(
Old Mar 29, 2013 | 12:48 PM
Vee's Avatar
Vee
Did you consider sending out your injectors for cleaning.
From these boards, I understand its been a very positive experience.
Old Mar 29, 2013 | 01:47 PM
smgdata's Avatar
WHAT!!! that's awful!!! hmm to rich yeah id be pretty stumped with that.
Bad sensor? maybe one of those full load switches is stuck? maybe fuel ECU?
Old Mar 30, 2013 | 01:39 PM
calvindoesntknow's Avatar
the ecu has an adjustment.on the side!
Old Mar 30, 2013 | 03:03 PM
Doug's Avatar
Originally Posted by Sarc
Hi Shawn
Right.
Plus....what's even more important is *flow* to *both* cylinder heads. This is where the partitioned radiator, clogs, and incorrect bleeding come into play.
I think most of the dreaded dropped valve seats are not the result of coolant temp (within reason, as you say) but lack of flow resulting in hot spots/steam pockets in the heads.
dsnyder586
Dec 29, 2024 07:39 PM
Jandreu
Jun 30, 2022 03:10 PM
Wahooesprit
Dec 23, 2019 02:01 PM
1100me
Sep 7, 2015 06:26 AM
Bcrary3
Sep 3, 2015 03:48 PM
