Transmission oil cooler hose
Old May 29, 2023 | 03:23 AM
Robbo D's Avatar
Default Transmission oil cooler hose
Morning all.
I have to replace one of my transmission oil cooler hoses. It’s the lower hose which has gone. I’m having another made up at a local Agricultural merchant. My neighbour works there so he is sorting it for me. Just wondering what sort of pressure goes through these hoses I don’t suppose it’s to high as the cooler is part of the radiator.
Rob.
Old May 29, 2023 | 06:23 AM
BenKenobi's Avatar
Pressure through the cooler is negligable, 5 psi or so.
Old May 29, 2023 | 01:11 PM
Robbo D's Avatar
Hi Ben.
Thanks for this much appreciated. New hose should be here tomorrow.
Rob.
Old Jun 3, 2023 | 08:04 AM
Robbo D's Avatar
Hi guys. Well bugger my neighbour’s work could repair my hose as they couldn’t get hold of the correct ends to make a new hose up. Any ideas as to what to do now.
Rob.
Old Jun 3, 2023 | 08:13 AM
BenKenobi's Avatar
Which ends do you need - a complete set of lines may be your option. Which ends are you stuck for ?
Old Jun 3, 2023 | 08:32 AM
Doug's Avatar
You might not need new ends. I can't quite remember how the hoses are configured but in some cases the rubber sections can be removed from the ends and new rubber hose crimped on.
Old Jun 3, 2023 | 08:59 AM
Robbo D's Avatar
Hi guys. Thanks for coming back to me. Yep a new plan. As you can see I have removed the old hose and am left with a couple of hose tails.
New plan is as you have said a new piece of hose and hose clamps. As the pressure is very low what sort of hose would you guys recommend.
Rob.
Old Jun 3, 2023 | 09:39 AM
jal1234's Avatar
Rob.
Get hose specifically designed for automatic transmission fluid. In the US, we can get it at any auto parts store. I'd imagine it's the same in the UK.tI like Gates hose, FWIW.
Jon
Old Jun 4, 2023 | 01:38 AM
Greg in France's Avatar
Earlier cars, but still HEs, have push-on hoses and clamps. The OEM hose used is very very strong indeed and still available. If nothing suitable, buy some of that, or get the hose from your buddies place that they would have used.
Old Jun 8, 2023 | 12:25 PM
Robbo D's Avatar
Hi all. A quick update. Here is the new pipe ready to fit. I used 400psi rated oil cooler hose. Will fit on the car on Saturday.
Rob.
rperformance
Jan 4, 2016 03:13 PM
Bhpbug
May 23, 2015 07:39 AM
weisberg
Dec 16, 2013 10:59 AM
orangeblossom
Feb 11, 2013 02:40 PM
RJK
Oct 4, 2009 03:05 PM
