Trolley Jack
Old Jan 8, 2022 | 06:08 AM
Robbo D's Avatar
Default Trolley Jack
Hi all.
Can somebody recommend a trolley Jack suitable for my XJS. I want one that will allow me to lift the car from the front under the bumper lifting on the front subframe. My idea is to place the Jack in the middle of the subframe and Jack up to full height then fit the stands underneath all in one go. I just don’t like using the jacking points to Jack up one side fit the stand then do the other I find it all a bit un nerving. Doing it this way will allow the job to be done in one action if you know what I mean. I’m in the uk so will need something available here. I have looked at a few and they will fit under the subframe just fine but not the spoiler. The jacks frames seem a bit to big. Any ideas.
Rob..
Old Jan 8, 2022 | 06:23 AM
Greg in France's Avatar
Originally Posted by Robbo D
Hi all.
Rob..
I have a couple of foot-square 3 inch deep wood blocks and drive the front wheels on to them, then my low profile jack goes in from the front no bother.
Old Jan 8, 2022 | 12:36 PM
orangeblossom's Avatar
Hi Robbo
You want what is known as a Low Profile Trolley Jack
I've got a low profile one and also a Standard Garage Trolley Jack and the Low Profile one is low enough to slide straight under the Front Spoiler, so that I can Jack up the Car from under the Front Cross Member, like you are thinking of doing which I always feel is the Safest Way
And always leave the Jack underneath just for a bit of extra 'Belt and Braces' although instead of Axle Stands which I already have, I much prefer to support the Front Cross Member on 2 Big Blocks of Hard Wood, just to make sure She can't fall
And also any time you need the Jack a little lower, on nearly all good Trolley Jacks you can remove the Round Jacking Pad to give you a bit more space
Here is a Pic of my Low Profile Trolley Jack compared to my Standard Trolley Jack so you can see the difference
In any event you need a 3 Ton Trolley Jack as anything less won't really 'Cut the Mustard'
Trolley Jack Comparison Low Profile vs Standard Trolley Jack
Old Jan 8, 2022 | 02:07 PM
Robbo D's Avatar
here’s a couple I’m looking at.
https://www.sealey.co.uk/product/563...th-rocket-lift
https://www.sealey.co.uk/product/563...-lift---yellow
Old Jan 8, 2022 | 03:12 PM
ptjs1's Avatar
Rob,
The Sealey ones are quite well made but not very cheap. I use a 3 ton SIP Omega jack, and a 2 ton lightweight aluminium ultra-low level jack.
If you're going in from the front to the subframe, it's helpful to have quite a long-reach and fairly heavy jack such as the Sealey type that you've shown. You don't have the big bumpers on your car which eases the problem but if you can get a jack with a saddle height under 80mm, you can get anywhere on the XJS. Have a look at 2.5 & 3 ton range from SGS. They have a very similar design and style to the Sealey ones but at 1/2 the price. Some of their equipment isn't at all bad. See here: 2.5 Ton Low Profile Garage Trolley Jack (sgs-engineering.com)
Paul
Old Jan 8, 2022 | 07:43 PM
alabbasi's Avatar
Costco sells Arcan jacks in both their UK and US stores. I've had the all steel one for more than a decade and their aluminum hybrid jack for about 5 years. Both are great reliable jacks and the costco deal represents great value.. Mine lift cars much heavier than an XJS.
Old Jan 10, 2022 | 09:29 AM
Robbo D's Avatar
Right lads. I have decided and this is due to being tight that I don’t actually need a low profile Jack. 4 small planks under the front wheels is a lot cheaper than a new Jack and it allows me to use my nearly new std 3ton Jack. I have however just ordered a new set of 3ton Sealey stands which should arrive in the next couple of days. I think I will make the planks into mini ramps and permanently fix them to the floor so when I back the Jag into the garage the front wheels will always be in the right position for jacking.
Rob.
Old Jan 10, 2022 | 09:46 AM
... I have decided and this is due to being tight that I don’t actually need a low profile Jack....
Rob.
The Third Rule of Acquisition plainly states, "Never Spend More Than You Have To."
Old Jan 10, 2022 | 10:40 AM
ptjs1's Avatar
Rob,
Remember that the bottom of that front subframe is prone to getting dented by jacks. Consider using a suitable block of wood to spread the load of the jack pad?
Paul
Old Jan 10, 2022 | 11:23 AM
Robbo D's Avatar
Hi Paul.
I always use a bit of ply between the jack and the subframe.
Rob.
Old Jan 10, 2022 | 11:52 PM
brinny's Avatar
I use a 2ton jack on the jacking point at the front to start off. That gives me enough clearance to put my 3 ton straight under the front crossmember.
Old Jan 14, 2022 | 06:36 AM
Robbo D's Avatar
New set up in place. Saved a few quid there
Rob.
Old Jan 15, 2022 | 03:58 AM
leep123's Avatar
Great fix Rob, looks very secure.
Even my low entry trolley jack will not clear the front spoiler on my car. The front will reach the subframe OK but then not enough space to work the lifting handle under the spoiler. Like you I am a little wary of the jacking points to support the full weight of the car so I just use them to raise the car body an inch or so and that enables me to work the trolley jack handle to do the serious lifting. To lower the car I just reverse the process.
Think I might look for a couple of planks to go under the wheels next time though!
Cheers,
LeeP
al_roethlisberger
Nov 11, 2022 08:01 PM
AndreasXJS
Feb 15, 2019 08:10 PM
paulyling
Jan 29, 2017 02:57 AM
Eaa
Sep 19, 2013 04:52 PM
compdude97
Feb 4, 2010 09:11 PM
