V12 5.3 HE gearbox mount: Easy and safe removal and refitting
Old Jun 30, 2015 | 10:35 AM
Greg in France's Avatar
Default V12 5.3 HE gearbox mount: Easy and safe removal and refitting
Guys
I have recently cured an most annoying driveline harmonic vibration that occured at about 130 kph. It was the propshaft, and following BB's news that new ones were still available, I bought and fitted it.
Of course on my old Range Rover/Alvis/etc etc this is a nice half hour job, while on the XJS it involves exhaust pipe, heatshield and gearbox support bracket removal. Which brings into play the dreaded gearbox V shaped mounting bracket and how to deal with the spring loading and separately support the gearbox while doing so.
I have always disliked and dreaded this aspect of our cars, so I have at last devised a safe,and easy method of removal and refitting it. proceed as follows:
i) Buy some 3/8 and 5/16 UNF threaded rod and cut two 5 inch pieces of each size. Obtain some nuts for each size too.
ii) To remove the V bracket, having undone the tongue shaped piece and the big nut on the end of the gearbox spigot, ONE at a a time, undo each of the four bracket securing nuts and thread into its place a piece of the rod (3/8 at the rear, 5/16 at the front bolt holes) and do up a nut with your fingers to keep the bracket secured.
iii) Secure the gearbox under the gearbox sump with a jack, wooden post, etc, so when the V bracket is undone the gearbox tail does not fall to the floor
iv) Then undo each nut a few turns at a time and gradually let the V mount drop and the gearbox mounting spring safely decompress.
v) Then having done what needs to be done, refit the bracket by placing it on the 'studs' and doing up the nuts. On the way up, aligning the V bracket perfectly is very easy to do by tapping it about with a wooden mallet, hide hammer, etc.
vi) Finally, when the bracket is fully home, undo one nut at a time and replace the stud with the original bolt.
Absolute cinch to do, no second jack, easy alignment. pics attached of the general idea.
Greg
Old Jun 30, 2015 | 10:42 AM
orangeblossom's Avatar
That is a Brilliant Idea Greg but one I hope that I won't have to do for some time.
Old Jun 30, 2015 | 11:16 AM
Brake buster's Avatar
nice work
and glad the new prop solved your problem
BB
Old Jun 30, 2015 | 11:36 AM
Bc xj's Avatar
thanks for posting. Good tip
Old Jun 30, 2015 | 05:35 PM
xjsv12's Avatar
What an interesting oil pan is.
Old Jul 1, 2015 | 02:16 AM
Lovely isn't it. I lusted after one for years an eventually a small windfall allowed me to buy it last year. It is a Moroso, rather dear but I picked it up a bit discounted. Superb quality, twin magnetic drain plugs at the downstream end, and it is made of TIG welded aluminium panels, NOT a casting, so it will not shatter if it hits something hard. The sealing lip against the gearbox casting is a very solid machined piece so seals extremely well too.
Greg
Old Jul 1, 2015 | 05:59 AM
baxtor's Avatar
You seem to have had only one washer Greg, those nuts look a bit inviting to the slotted holes.
Old Jul 1, 2015 | 06:26 AM
Just a mockup for the cameras, Baxtor, when used in anger all the correct bits were in place, I can assure you!
Greg
Old Jul 1, 2015 | 07:33 AM
Doug's Avatar
These complex trans mounts are truly 'interesting design features'. Jaguar had quite a love affair with them for decades and perhaps still does, I dunno.
Of course Jaguar has always, and admirably, focused on minimizing NVH --Noise, Vibration, Harshness-- but utter smoothness and silence can be achieved so much more simply. I wish some of the money spent on transmission mounts could've been diverted elsewhere, perhaps (for one example) to upgrade the window switches? I'm sure Jaguar spent no more than 49-cents apiece for those !
Old Aug 14, 2020 | 10:17 PM
HeyCharger's Avatar
Hi GIF,
Is this the standard transmission mount?
I seem to remember someone saying they weren't up to it these days.
Old Aug 15, 2020 | 01:06 AM
darrhel's Avatar
Guys
Greg
Attachment 154282
Attachment 154283
Attachment 154284
sensational
Old Aug 15, 2020 | 01:56 AM
Originally Posted by HeyCharger
Hi GIF,
Yes, standard pre facelift V12 mount. 6 cylinder cars and post facelift 4 speed auto V12s were different.
aholbro1
Dec 29, 2024 06:46 PM
cissdm
May 3, 2016 06:02 AM
Rlover
Mar 30, 2016 10:04 PM
kstevusa
Sep 7, 2015 01:12 PM
1100me
Sep 7, 2015 06:26 AM
