Wanted: Trick for Covering Door Locks in Car Wash
Old Jan 3, 2018 | 01:56 PM
Andreas Schmieg's Avatar
Default Wanted: Trick for Covering Door Locks in Car Wash
Who would have thought that the main challenge with driving a Jaguar XJS in the winter is that I can’t get into the @#$%%! car. I have a great touchless car wash nearby (5 miles) that gets all the ice, snow and salt off the car including an underbody wash. Unfortunately, both of my door locks are now frozen solid and while I can get a key in them, it is impossible to turn the key. Spraying WD40 into the key hole does not help either. When I locked the car last night, it felt that there was 'a click missing', so while the doors are shut, something did not engage and now it is jammed (metal on metal).
So I will spend my evening with an extension cord and a hair dryer in the driveway.
Now my question: Is there anything I can stick into the door locks before going to the car wash to keep the water out? It is a touchless carwash with pressure washers on steroids. I was thinking of a rubber plug or a piece of medical tape to cover the key opening. Any ideas? Or will the water get in through the door handle anyway?
Attached Thumbnails Wanted: Trick for Covering Door Locks in Car Wash-jaguar-xjs-door-handle.jpg
Old Jan 3, 2018 | 02:55 PM
kjopen's Avatar
I've held my key partially in the lock whilst using a cigarette lighter on the other end and freed many a frozen lock.... as for preventing water ingress something as simple as duct tape over the whole handle just before you drive in the car wash??
Old Jan 3, 2018 | 03:12 PM
Originally Posted by kjopen
(...) duct tape (...)
I like the way you think. Since WD40 doesn't work, try Duct Tape.
Old Jan 3, 2018 | 03:25 PM
Jagsandmgs's Avatar
Try a new or good used door handle/lock. They’re supposed to have a little sliding door over the key hole and yours appears to be missing/stuck open.
Old Jan 3, 2018 | 07:01 PM
Steve M's Avatar
I'm not entirely sure what a touchless car wash is but here's a tip; don't!
Bucket, water, sponge.
Warm water, cold water, Evian: your choice.
What ever era of Jaguar that you have, or wherever that you live, do not subject it to pressurised water.
That way only tears and madness arise.
Old Jan 3, 2018 | 07:19 PM
Mikey's Avatar
Stop washing the car in freezing weather.
Old Jan 3, 2018 | 07:23 PM
My hair dryer thawed the stubborn door lock.
Attached Thumbnails Wanted: Trick for Covering Door Locks in Car Wash-20180103_191224-1.jpg
Old Jan 3, 2018 | 07:34 PM
Steve M's Avatar
You probably shouldn't admit that you have a hair drier.
Old Jan 3, 2018 | 07:46 PM
I am just happy to have hair. :-)
Old Jan 3, 2018 | 11:26 PM
Daim's Avatar
Buy some lock de-icer. Or the extreme way: spray some antifreeze into the lock. Then DON'T use WD40. WD40 is NOT a lubricant. Instead get some graphite spray and spray some of that in there. Done. Easiest was would be to avoid car washes in winter anyway and go when the temperatures are above freezing (dunno how many 'hundred' degrees Fahrenheit that would be, as only America uses that...). I managed to get frozen into my Volvo one time. After that, I made sure that I either dried the car off before driving away OR didn't wash until warm.
WD40 is only a rust solvant. It will not lubricate for long. And even then there are better products out there. I like to use Güsol, an aerospace and Airbus approved solvent which will undo ANY screw and nut... Just for te record.
Old Jan 4, 2018 | 07:03 AM
orangeblossom's Avatar
Hi Andreas
How about putting a couple of round Magnets over the door lock key holes to stop water getting in while She is in the Car Wash
Probably best to put the Magnets in some small gauze bags, to prevent any damage to paint in case they get washed off
I never use a Car Wash myself, as 16 Vestal Virgins wash her in asses milk and then once having done so they dry her with their hair
Old Jan 4, 2018 | 11:31 AM
JagCad's Avatar
WD40 has a wide reputation for usefulness. Most of the uses are not the best use of the product.
Poor at best as a rust preventative or lubricant.
It dates back to DOD spec's. A desicant. I have some in GI form.
It's been a while since I washed either of my steeds. Not going to, in the cold. although, a real freeze is seldom seen around here. A few night when the night dew on hard surfaces became a very thin layer of ice. Melted rapidly.
And, yes, graphite is the lube of choice for locks. Although, my local locksmith counseled, "clean and dry", no lube needed. I took my NOS
ignition switch with me when I had a duplicate key made.
Carl
Old Jan 4, 2018 | 02:26 PM
sidescrollin's Avatar
The lock has a metal cover over it, you shouldn't really be getting much water at all in through the metal flap.
WD40 is mostly a cleaner, try something like white lithium grease to abate the water if you must.
Old Jan 4, 2018 | 08:55 PM
malc4d's Avatar
Funny..I thought it stood for Water Displacement, 40th formula.
https://en.wikipedia.org/wiki/WD-40
Old Jan 5, 2018 | 02:24 PM
Too bad the silly spray can can't read. It did not do the trick for me. :-)
Old Jan 5, 2018 | 07:08 PM
JessN16's Avatar
Couple of suggestions. Not saying either of these work for this application but I'm throwing it out there anyway...
1) Covering a lock cylinder: Silly Putty. Since you said touchless car wash, that is. If it's truly touchless (meaning no rotating brushes) I think the silly putty will hold. Plumber's putty should also, but it doesn't come off as cleanly. Just grab a big handful, cover the lock and part of the handle before you roll into the wash.
2) Lubricating a lock: Gun oil. Make sure it's one-stage, though. I realize locksmiths preach dry graphite but I fixed the old locks on the building I work in (a bank) with a spray can of gun oil, purchased from a local Wal-Mart. About $6 for a can, I think, and that was two years ago and our locks work great. I've used the same product in several cars, Jags and not, with great results. It smells like WD-40 but it's something different. And I have no idea whether it will prevent freeze-up. The important part about getting a one-stage versus a two-stage oil is the two-stage will separate in the can. It's still better than nothing, though.
Jess
Old Jan 5, 2018 | 11:55 PM
89 Jacobra's Avatar
Active Streak: 30 Days
Take the little plastic plug you use to stick in electrical wall receptacles to child proof them and cut one of the plastic tangs off. The other tang should slide into the key slot, and the flat part will completely cover the lock area of the door handle. Second don't ever spray the water directly into the lock portion of a door handle as your only asking for trouble.
I hope the Image comes through.
Jack
Old Jan 6, 2018 | 09:54 AM
Doug's Avatar
Water displacement, yes. But not ice displacement
If you squirt it into the locks before the water freezes it'll do the trick.
As for WD40 in general.....
I love the stuff; use it for 1001 tasks. Lubrication isn't one of them.
Old Jan 6, 2018 | 01:37 PM
Originally Posted by Doug
As for WD40 in general..... I love the stuff; use it for 1001 tasks. Lubrication isn't one of them.
My dad tried WD40 on his sore throat. Didn't work. Plus it tastes horrible. :-)
Old Jan 6, 2018 | 05:27 PM
89 Jacobra's Avatar
Did What??? I'm pretty sure that wasn't the smartest thing to do, as I'm sure there are warnings all over the can telling you not to do it???
Jack
User 070620
Jun 22, 2015 02:04 AM
dd823
Oct 23, 2012 04:43 PM
ixj8it
Jan 13, 2011 07:00 AM
Goldlion
Nov 30, 2009 12:12 AM
