What did you do to or buy for your XJ-S/XJS today?
Old Feb 5, 2018 | 06:21 PM
  #861
Andreas Schmieg's Avatar
Early 1975 XJ-S canister style oil filter housing.
Found it in Germany. Just arrived today.
Not that I would be an all original freak. :-)
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-20180205_181238.jpg
Old Feb 6, 2018 | 10:46 AM
  #862
Stargazer XJS's Avatar
Picked her up from the shop with a new transmission mount. Hoped it would take care of the grinding sound and the clunks. I'm happy to report that the clunks are a thing of the past, but I'm still getting a grinding from the transmission tunnel in park, neutral, and throughout acceleration. I'm in over my head and might have to sell this summer.
Old Feb 6, 2018 | 11:41 AM
  #863
Greg in France's Avatar
If you have a V12 pre HE, there is a decent likelihood that the box is sitting against the rearmost of the two fixing brackets; the one that bolts up into the tunnel below the propshaft. It is easy to miss out some of the fixing bolts (1 in the diagram, and easy to misalign it, or have it too close to the gearbox. Worth a look, anyway.
Also it is quite easy to misalign the actual V shaped plate the mounting sits on, too.
Old Feb 17, 2018 | 10:12 PM
  #864
She's an '88 V12. Are there similar structures that would cause a similar behavior in HE vehicles?
Old Feb 18, 2018 | 03:16 AM
  #865
Apologies, I meant to write pre-FACELIFT. Your car is exactly as in my diagram in my pervious post.
Greg
Old Feb 18, 2018 | 08:47 AM
  #866
Daim's Avatar
Bolt the AC compressor to the V12. I was missing two screws. But I knew I had them. As they aren't available anymore, I had to find them. And where were they? In the old Harrison A6 cylinder head...
Why on earth did Jaguar think it would be a good idea to use M8s at the front and imperial what evers at the rear!? And then use some imperial screws to mount the half imperial front bracket... Darn Jaguar!
Old Mar 1, 2018 | 04:37 PM
  #867
pablomonk's Avatar
What did I do to my XJS today.....???
Straightened out the main bumper bar.
Took the bumper chrome trims to a local body shop to see if they can level them out again.
Fitted new indicator (but it looks too new, so will need to get another new one for the other side to match).
... oh, and fitted new gas struts in the boot (old ones tired).
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-dscf3589.jpg
Old Mar 2, 2018 | 03:37 PM
  #868
warrjon's Avatar
I bought this last week to replace my small Sheraton (same as South Bend 9"). I can now machine my new water rails and adapters.
I also bought a new Milling Machine to bore the water manifolds. Haven't picked up the mill yet.
Old Mar 2, 2018 | 04:07 PM
  #869
brinny's Avatar
Got lots of proper work lined up for it I presume ?
Old Mar 3, 2018 | 09:11 AM
  #870
Daim's Avatar
Jelly!
Old Mar 4, 2018 | 07:31 AM
  #871
JigJag's Avatar
Also jelly. What’s your water manifold design look like?
my most recent project was a new water pump, and spoiler repair. Still on that.
Old Mar 5, 2018 | 02:05 AM
  #872
warrjon's Avatar
I'm using the stock manifolds, that have restrictors added to the front manifold, then I plan on machining the manifold outlets to take 25mm aluminium pipe. When I have them done I'll post pics in my engine build thread.
Old Mar 6, 2018 | 03:57 AM
  #873
pablomonk's Avatar
Re fitted straightened chrome to front bumper and vinyl wrapped ski-slope till I can find a replacement.
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-dscf3607.jpg   What did you do to or buy for your XJ-S/XJS today?-dscf3613.jpg   What did you do to or buy for your XJ-S/XJS today?-dscf3397.jpg   What did you do to or buy for your XJ-S/XJS today?-dscf3610.jpg
Old Mar 6, 2018 | 08:22 AM
  #874
Steve M's Avatar
Took it out today and gave it loads of beans.
Great fun!
Old Mar 21, 2018 | 08:15 AM
  #875
Some Day, Some Day's Avatar
New Shoes for the Old Lady....
The old Michelin tyres, from 2012, were developing cracks all around the shoulder where the sidewall meets the tread. Not ideal. So I ordered some Continental ContiPremiumContact2 tyres (same as I got for the rear last year; there's sod-all choice for 225/60-R15 tyres over here. These, some Bridgestones with white lettering on the sidewall, Falkens, Nonamebrand, and that's about it), and trundled along to a local garage/tyre place.
Cracks along the old Michelin tyre. It's getting a bit past it.
Hope this was the right place to jack her up. I seem to remember some precautions, but a quick check as the garage guy was manoeuvring the jack into place only warned me not to jack under the radiator.
Nicely polished brake disc - at least on the flat surface. Rust elsewhere. Everything else looks pretty clean.
If Reliant got their hands on a Jaguar XJS it might look a bit like this.... The rear was chocked on the other side.
Old Mar 21, 2018 | 11:28 AM
  #876
JigJag's Avatar
This is not specifically Jag related, hope that's ok, but I bought Jessie ( my 86 XJS coupe ) a friend her age to play with!
My girl has been looking for a pre-85 MB diesel for several years since hers got totaled by an inattentive driver. This one's a 1980 rust-free time capsule in Cactus Green. Parked in 2000 in the first owners garage. And he just uncovered it for us after 17 years. That's a 250K mile badge. Just getting broken in good.
Old Mar 21, 2018 | 01:13 PM
  #877
I thought all facelifts had 16 inch tyres? Is the above a typo?
Old Mar 21, 2018 | 01:23 PM
  #878
brinny's Avatar
My 1991 is on lattice 15” but the spoked alloys are 16”
Old Mar 21, 2018 | 02:09 PM
  #879
Thanks Brinny. I changed my original starfish wheels to the later 16 inch 5 spokes, because even 15 years ago 15 inch tyres with the right speed rating were getting both very expensive and rare. Now it is even worse.
Old Mar 21, 2018 | 06:40 PM
  #880
Nope. Definitely 15 inches. They must have moved to 16 inches in 1993 or later. The facelift changes didn't all happen at once. For example, the door handles didn't change to the flap sort until about 1993.
It's not totally clear, but here's the old front tyre.
225/60-R15 on a 1992 facelift coupé.
