What did you do to or buy for your XJ-S/XJS today?
Old May 15, 2020 | 03:40 PM
  #1361
JayJagJay's Avatar
Originally Posted by Hoppy
Hoppy! THAT is a really nice color!
Is it original or did you have her painted?
Old May 15, 2020 | 03:42 PM
  #1362
JayJagJay's Avatar
Default I drove her!
Nice 2hr drive... First time really...
What an amazing machine!
Just looking over some things.
Old May 15, 2020 | 08:28 PM
  #1363
stran0020's Avatar
how you get there good to stick up so much? Mine prolly goes up about half or even less then that
Old May 15, 2020 | 09:56 PM
  #1364
JayJagJay's Avatar
I have 2 intact grills at home, but the grill I have in the car now is in rough shape and I don't care so much about it. It's cracked in a way that allows me to raise the hood ALL the way. It creeks and groans a little everytime I open it, lol
I've never had the struts connected as over this last 1 1/2 - 2 years.... Im working under the hood so much that dealing with the struts to open the hood WIDE would just be a PITA. But, funny you ask. I was fitting the struts today for the first time... Things are getting good!
Old May 16, 2020 | 04:48 PM
  #1365
garethashenden's Avatar
Just about done with the front left corner. New ball joints and bushings. Today I replaced the brake disc and pads, resealed the calliper, and replaced the flexible hose. Still need to do the tie rod end, sway bar bushings, and the other side.
Old May 18, 2020 | 04:31 PM
  #1366
Hoppy's Avatar
I've had it resprayed in the original Westminster blue, the best colour I reckon
Old May 24, 2020 | 07:47 AM
  #1367
rgp's Avatar
rgp
took my xjs to have the auto gearbox rebuilt with new seals and whatever, but the mechanic decided to road test it without releasing the hand brake, it ripped every pad off the backing plate, so I took the cradle down and sent everything brake wise off to wards in Colchester for a reconditioning, he had already done my uj's and rear hubs and the last time I did my hand brake was in 2000 so they were on my to do list.
Old May 26, 2020 | 11:49 AM
  #1368
Daim's Avatar
Nearly finished the transmission mount...
Old May 28, 2020 | 09:10 AM
  #1369
Dleit53's Avatar
I experienced the joy of cleaning the surge tank! Darn, that was nasty!
Old Jun 4, 2020 | 12:22 AM
  #1370
Daim's Avatar
Don't you just love freshly resurfaced parts?
Old Jun 5, 2020 | 09:54 AM
  #1371
rgp's Avatar
rgp
got my rear brakes back from Wards
(jag axles) great job, should see me out
Old Jun 5, 2020 | 03:03 PM
  #1372
Daim's Avatar
Transmission mount now finsihed... Yes! Looks like new again
Old Jun 28, 2020 | 03:53 PM
  #1373
rgp's Avatar
rgp
This post was intended as an addition to my previous post. But didn't work
Old Jun 28, 2020 | 09:53 PM
  #1374
Mikekeay's Avatar
Well forgive me to replying to this 6 year old blog, but may I ask, where or whom supplied the parts.
just out of pure interest for my future interest.
mike
Old Jun 29, 2020 | 03:40 AM
  #1375
Asdrewq's Avatar
Originally Posted by rgp
On further inspection they jacked it up on a 4 armed type ramp on the jacking point, it pushed one of the front nipples straight up into the cavity above. So had to weld new one on. Only £9 but the guy was a jag trained man eligedly. So didn't he know the nipple is only a guide for the supplied jack. And it's still leaking, going back july
I think I've read about the mounts collapsing being quite a common thing. Did you reinforce the Internal structure at all when it was repaired?
How are you supposed to position a jack around these nipples then? Use some sort of puck with a hole in the middle?
Old Jun 29, 2020 | 10:57 AM
  #1376
Dukejag's Avatar
If your talking jacking the car up on the jacking points I use pieces of plywood with holes cut in them for the locating lugs / nipples.
I never jack up the car directly on them, Not sure if they would hold? Looks like they may not based on the above.
Old Jun 29, 2020 | 11:39 AM
  #1377
rgp's Avatar
rgp
As jagduke jag says. + I have 2 offcuts of 4x2 with a hole drilled in them or I use 2 large sockets Plus the actual point of contact for the jack was sound so no remedial work required. Its purely the fact of metal fatigue after nearly 40 years of fitter abuse.
Old Jul 1, 2020 | 02:05 AM
  #1378
Some Day, Some Day's Avatar
Muck galore! Thanks to
's class in cleaning the PCV, and having a bit of free time when it wasn't raining, I decided to take a look a mine. Unlike his, my cover is held on with a plastic tie strap, which probably isn't correct, so I hunted down a hose clip thing that looked about the right size. Then I could tackle the job.
The top came off really easily, and I could just slip the old tie right off. Just as well, as it turned out. And now I could see the PCV filter.
Yuck!
This isn't supposed to be brown.
Extracting it reveals even more muck.
A mucky pool of mucky muck sits at the bottom of the housing. This probably isn't ideal, I feel.
I can get quite a bit out with my (gloved!) finger, then use parts cleaner.
Now it's nice and clean, or at least as clean as some shop towels and parts cleaner can get it.
In the meantime, the filter's been soaking in an old yoghurt container with parts cleaner.
Good scrub with an old toothbrush to remove as much brown varnish muck as I can.
I can see the sky through it, but only a little bit through the middle. How much sky should I be able to see?
Much cleaner now. Back she goes. But there's a slight problem. My hose clip wasn't quite big enough, and was a bit too wide to be ideal. So I managed to get the old plastic one back on and it sits as firmly as it ever sat before, which is "requires a good twisty pull to remove." I will get a larger, thinner clip as soon as I can, however. But the car starts and runs.
In the meantime, I've discovered that the hose at the other end of the PCV filter pipe needs replacing, and there appears to be a coolant leak in my new (2016) aluminium radiator from Wizard.
Yeah. This doesn't look ideal. Right at the left (port) edge on the inside. Oh well.....
Old Jul 1, 2020 | 02:20 AM
  #1379
Greg in France's Avatar
SDSD,
carefully check the top hose on the rad intake that side, and see if a finger drawn across the end of the hose/spigot of the rad join shows any wetness. the leak could just be a hose seal problem.
Old Jul 1, 2020 | 02:24 AM
  #1380
I hope you're right. I'll check next time the car's been running, because any coolant will have dried by now. Actually, I could take my boroscope and see if the underside of the join is mucky and green.
