whats your oil pressure?
Old May 30, 2011 | 08:19 PM
sidescrollin's Avatar
Default whats your oil pressure?
i just fixed my banjo leak at the sending unit and replaced the sending unit the other day.
At startup my pressure is around 65 but after driving about 20 miles today it went back to doing about 25 stopped and 55ish while driving.
Is this from the oil heating up or did something else start leaking??
what pressure do you guys typically have? running 0w-40 btw and even at 65psi right not my oil light stays on.
thanks
Old May 30, 2011 | 08:27 PM
plums's Avatar
The lowering of pressures after warmup is to be expected. The numbers you are seeing are about right on a lot of non-Jaguar cars.
65 psi is actually a bit on the high side for a 0W40 oil.
Old May 31, 2011 | 11:10 AM
so you think those numbers after warmup at around 25 idle and 50 cruising sound about right?
its just my immediate thought yesterday was, "oh great, now something else is leaking". But then i remembered the car was actually warmed up, but i still thought it was odd with two things now sealed the pressure was so similar.
then again it wasn't a BAD leak, maybe im just worrying to much. And maybe the burning oil smell was just what leaked out when i had it apart and it only just then got hot enough to burn off.
Old May 31, 2011 | 11:36 AM
Doug's Avatar
Those results sound good to me....even better than average if you have a V12.
The V12s usually have very low pressure hot, at idle. Like 5-8 psi...which causes some concern but is normal.
Old May 31, 2011 | 12:43 PM
aight thanks doug, just what i needed to hear XD
i guess my idiot light is now broken though haha
Old May 31, 2011 | 01:10 PM
EcbJag's Avatar
At idle hot on mine, the needle is at the first line. At cruising, bottom to middle of the 50.the sensors for the light and gauge are separate.
Old Jun 1, 2011 | 08:29 PM
i know, i just mean my oil light stays on now. even with the other stuff fixed, so the sensor for that light must've gone bad lol.
thanks for the input on what your pressure it though, makes me feel alot more comfortable lol.
Old Jun 1, 2011 | 09:40 PM
bigwiki's Avatar
The oil pressure gauge numbers in my 95 4.0L is 0,4,8. I am not sure if it is in Bar or PSI. After engine warmed up, the scale is 1 at idle and around 5 in driving.
I am using Mobil 0w30 oil.
Old Jun 1, 2011 | 10:06 PM
cadfael_tex's Avatar
Sounds just like my 94. Don't have a light and mine is about 1 on idle and just under 6 while driving.
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
jerry_hoback
XJ40 ( XJ81 )
Sep 13, 2015 07:48 PM
mhamilton
Sep 12, 2015 03:21 PM
giandanielxk8
Sep 6, 2015 07:21 PM
