Winter Plans for XJS
Old Sep 1, 2014 | 12:46 AM
user 652867429824's Avatar
Banned
Default Winter Plans for XJS
Yep, already thinking winter, or more like what I plan on doing for my 84 XJS. Chang out the Fuel injector rail, hoses and Injectors (have a spare ready to go in) Checck wires under hood and repair/re-wrap . Make up a new fuel injector wire harness and get it out of "The V".
I also would like to upgrade the ICM to a crane cam with recommended coil. I realize the 84s have 2 coils, if I upgrade to the XR700 or one of the other Fireball sytem, do I have to retain the 2 two coil system
Last edited by user 652867429824; Sep 1, 2014 at 12:47 AM. Reason: make correct on one explaination
Old Sep 1, 2014 | 02:06 AM
malc4d's Avatar
Cant wait for winter.......It will be great to be able to get the car out and the roof down and use it more during the day.
Its just sooooooo dam hot here in the summer that l mainly use the car in the evenings.
Old Sep 1, 2014 | 07:08 AM
JTsmks's Avatar
Same here, winter is for D-R-I-V-I-N-G!!!
Old Sep 1, 2014 | 09:09 AM
Roger95's Avatar
Same here!
Old Sep 1, 2014 | 10:40 PM
Banned
Default not here
here in Nebraska, winters are cold. but hope someone can answer my original question on the change over to the crane cams fireball system
Old Sep 2, 2014 | 12:13 AM
calvindoesntknow's Avatar
Do you have pre he or he ignition? Assuming its he, I would use the factory coil pick up and just run an msd 6a ignition box
Old Sep 2, 2014 | 12:24 AM
Banned
I have the HE, thanks
Old Sep 2, 2014 | 03:19 AM
Tyran66's Avatar
All that "extra" foot heat from the V12 has it uses come winter time
Old Sep 2, 2014 | 10:10 AM
XJSFan's Avatar
Just going to park it with a full tank of gas... Already did the coolant and changed the oil with a new filter and Mobil 1 0W40...
Old Sep 2, 2014 | 05:38 PM
chriskindbooks's Avatar
Covered hibernation for six months. Change oil 15/50 mobile synthetic with a storage conditioner in gas. It sure makes it so easy to start come spring. Three plates of mothballs on engine to discourage any mouse from building a nest, it seems to work.
Old Sep 2, 2014 | 06:46 PM
malc4d's Avatar
omg.......move south. lo l
Old Sep 2, 2014 | 08:34 PM
JTsmks's Avatar
Make sure it's non-ethonol gas!
Old Sep 11, 2014 | 03:45 AM
Banned
Default which # did you buy
Which # did you buy and did you cange the coils to a single or did you keep the double coil system. and do you have pics on how you wired yours up
Old Feb 13, 2015 | 09:21 AM
Banned
sometime ago I wrote what I would like to do, whould like to know if you have pics of your set up and notes on how you wired it. plus the modle msd 6 you bought
FrickenJag
Jun 16, 2025 02:15 PM
Rivguy
Dec 4, 2020 07:55 AM
sogood
Sep 15, 2015 07:35 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
1100me
Sep 7, 2015 06:26 AM
