Wiper issue, how to proceed ?
Old Mar 25, 2020 | 01:39 PM
yellowapple's Avatar
Default Wiper issue, how to proceed ?
Hello everybody,
I'm facing a wiper issue on the 1983 XJS for a long time, it started with rain on the wiper engine not covered anymore by the plastic protection. Thank you to the garage, my car was outside.
Now I've replaced the engine but this is still not running. What can I check ? Fuse box ?
Thank you.
​​​​​​​Ya
Last edited by GGG; Mar 26, 2020 at 04:13 AM. Reason: Add Model and Year from post #3
Old Mar 25, 2020 | 03:16 PM
Greg in France's Avatar
Originally Posted by yellowapple
Hello everybody,
I'm facing a wiper issue for a long time, it started with rain on the wiper engine not covered anymore by the plastic protection. Thank you to the garage, my car was outside.
Thank you.
Ya
Please say which of your vehicles has he problem, as they do not have the same wiper system or column stalks. Check as follows:
  • fuse, and test for current BOTH sides of the fuse, they often look entire but have failed at the connection internally.
  • If OK, then test the wiper stalk in ALL its settings: normal, high speed, flickwipe, intermittent. This is to eliminate (to a degree) a possible stalk-switch problem on an individual mode. If nothing:
  • remove the wiper unit an unplug it, from the black socket on the bulkhead, then turn on the wipers to normal speed and using a test light see if there is current to the socket (there are several connectors in the socket but one will be live, if not two). Switch off and test that this connector goes dead.
  • redo this test with someone holding the stalk on the flickwipe setting and check for current again.
Post again after this test. But in principle, if there is current to the socket, the problem is in the motor unit somewhere.
Old Mar 26, 2020 | 03:10 AM
Thank you Greg, the 1983 is concerned.
I'll start the investigation today.
Sean B
Dec 8, 2022 07:42 AM
RichardPhuket
May 15, 2017 07:46 AM
carelm
Mar 3, 2015 11:49 AM
nebelfuerst
Feb 6, 2013 06:10 AM
89JAGXJ6
XJ40 ( XJ81 )
Oct 18, 2010 03:51 AM
