Xjs won't start. No spark
Old Oct 24, 2014 | 12:11 PM
sainmatt's Avatar
Default Xjs won't start. No spark
Hey guys,
Went to crank her up and it turns over fuel pump is running but no spark. I pulled bank a and b coil and grounded to fuel rail with no spark.
Any advice is much appreciated!!!
Old Oct 24, 2014 | 01:28 PM
sidescrollin's Avatar
Please spend 20 dollars on a multimeter, it will improve diagnostic abilities tenfold and prevent you from attempting to create a spark on a fuel rail...
Is there proper voltage TO the coil?
Old Oct 24, 2014 | 01:47 PM
sainmatt's Avatar
I have a multimeter. I admit spark testing on the fuel rail wasn't wise.
I just replaced all spark plugs, did silicone on marelli rotor, and replaced all fuel hoses. So I have a pretty understanding of what's under the hood. I just have NO idea what the pinouts are or where to check for voltage on the coil.
Should I be getting 12v on the connector while the ignition is on or only while starting?
Old Oct 24, 2014 | 01:55 PM
robbinpace's Avatar
On my 87 and 85 it was the ignition amp.
sainmatt's Avatar
And I drove the car earlier in the week. So it's ran beautifully since doing the work mentioned.
It has bee slow to start for a bit - by that i mean the engine will instantly turn but it has to turn for about 2 or 3 seconds before it actually cranks.
Old Oct 24, 2014 | 02:07 PM
sainmatt's Avatar
Now that I think about it. The fuel rail was a terrible choice for a test, not only because of explosion possibility but it's suspended by fuel hose and doesn't make ground contact anywhere.
Not sure it would have sparked even it coils were getting spark.
Old Oct 24, 2014 | 03:48 PM
lolol. It could be further back, I am just recommending you work your way back until you find the problem.
there should be 12v feeding into the coil
Old Oct 26, 2014 | 09:15 PM
bocagq45's Avatar
Make sure the front crank sensor is plugged in. Also, you might have tripped the inertia switch in the drivers side door jam.
Old Oct 27, 2014 | 12:41 AM
Japthug's Avatar
When the battery is weak it is taken all the energy by the starter and can't afford to supply enough energy to the coils. You could check the battery too.
Old Oct 27, 2014 | 03:40 PM
sainmatt's Avatar
Where is the crank position sensor located?
Old Oct 27, 2014 | 03:49 PM
sainmatt's Avatar
Also, the tachometer has been down for a while. Stuck on 2000rpm, but it's been starting and running fine until a couple days ago. It's been slow to start for some time.
Old Oct 27, 2014 | 04:48 PM
its gonna be right around the dampener up front somewhere. Since it is checking the crank position it has to be right on the crank. I don't personally know if its further to the left, right, up, or if its near something that makes it easier to find. It is hard to get a look down there, but there shouldn't be many other wires leading into that area.
Old Oct 28, 2014 | 04:44 AM
Japthug's Avatar
The crank sensor is right under the crank pulley. You will have to see it from underneath the car.
The photo attached shows the sensor location, the blue arrows are the securing bolts (note the pulley is taken off)
Old Oct 28, 2014 | 11:54 AM
Doesn't the tachometer run off the rear speed sensor, which isn't involved in ignition timing?
Old Oct 29, 2014 | 12:00 PM
Japthug's Avatar
At least the 26CU Marelli ignition cars take the taco signal from the ignition coil, so I think 16CU cars are the same.
To ignite, I think both sensors are needed.
dsnyder586
Dec 29, 2024 07:39 PM
Dagny
Jun 11, 2024 01:06 PM
Charlene n John
Sep 28, 2015 06:01 AM
joesoap
Sep 10, 2015 01:09 AM
Charlene n John
Sep 6, 2015 11:03 AM
