13MY Convertible Top and Headliner Replacement Procedure
Old Dec 2, 2024 | 03:26 PM
djhaydel's Avatar
Default 13MY Convertible Top and Headliner Replacement Procedure
Prior to replacing my convertable top and headliner I did alot of research and planning to do it my self.
I have updated my plan with more infomation based on my experience and would like to share it with others that ar considering DIY.
This isn't rocket science but does take some time I would allow at least 2 -4 days and you would also need a helper.
Lots of blankets to throw over the interior and exterior.
The PDF file is attached..
Old Dec 2, 2024 | 11:59 PM
kj07xk's Avatar
I smell a sticky coming….
Well done!
Old Dec 3, 2024 | 01:08 PM
earny's Avatar
Thx a lot - this is extremely helpful. Plan to do the replacement myself together with a friend.
Old Dec 4, 2024 | 11:03 AM
djhaydel's Avatar
Thumbs up
First of all I hope you are very sucessful and all goes smoothe.
Should you need any additional information please feel free to private message me and I will try to respond quickly.
Should you have any additional details\clarifications that this procedure could use let me know and I will consider an update.
Old Dec 7, 2024 | 05:11 PM
djhaydel's Avatar
Default Updated Procedure
[QUOTE=
Should you have any additional details\clarifications that this procedure could use let me know and I will consider an update.[/QUOTE]
As it goes the clamps for the cables at the front didn't have enough padding as compared to the original top ones and obsereved that they were starting to show a mark in the outer top.
Essentially an easy repair (just had to remove the overhead trim piece and the weather stripping in that first segment of the top and nade the modifications:
1) bent the tips downward so they were flush and smoothed the edges.
2) added an extra piece of Gorella black fabric tape over them. Similar to what was on the origanal factory top had.
With that side I revised the procedure to include those details.
I'm still not quiiet satisfied with the headliners gap at the sides, I manage to get it to about 1" but the original was much closer.
If anyone has replaced the headliner I would like feedback on what if any gap exist, thanks.
Old Dec 7, 2024 | 05:49 PM
Stuart S's Avatar
Hi Dana,
Photos would be helpful, thanks.
Stuart
Old Dec 8, 2024 | 09:27 AM
djhaydel's Avatar
While I didn't photo the marks you can sort of see the marks @ the arrows and the general area and the location of the clips on the other picture. It is approximately 5" back from the fron edge of the top and close to the side edge of the top. you can see the adhesive left from the cover Hope this helps.
Stuart, could you give me an idea of how much of a gap if any between your headliner edge and quarter casings along the sides.Thanks
Cable clips
Cable clips
Area of marks
Area of marks
This would be directly on top the area that the roof cables attach.
Old Dec 8, 2024 | 11:00 AM
Stuart S's Avatar
Dana,
I hope these photos will help. There aren't any gaps along the edges of my headliner. Let me know if you need any more photos.
Stuart
dougxk
May 24, 2022 03:46 PM
jagtoes
Jul 31, 2016 07:46 PM
hdsg
Jan 10, 2016 07:13 AM
batroute
Jan 17, 2015 07:45 PM
randyb
May 31, 2013 03:43 PM
