2007 xkr misfire issue
Old May 2, 2018 | 01:59 PM
Busyb187's Avatar
Default 2007 xkr misfire issue
Hello everyone. I recently bought a 2007 Jaguar XKR. It has 100,000 miles. The check engine light turned on. I pulled codes P0300, P0302, P0304, P0306, P0308, and P0316. It has a minor misfire at idle. And also when I accelerate i feel as if it hesitates. Any ideas or suggestions will help. And thank you all in advance. By the way, other then the misfire issue I love this car.
Old May 3, 2018 | 01:39 AM
Patrick Wong's Avatar
Since you have misfire codes all on the same (left) side of the engine, I am wondering whether you might have a failed engine head gasket which impacts all cylinders on that side. However, I would start by removing and inspecting the spark plugs since that is a relatively easy task. While the plugs are out, perform a cylinder compression check to verify whether any cylinders have a problem.
The iridium spark plugs should be replaced at 100K miles anyway.
https://www.jaguarforums.com/forum/x...system-191533/
Old May 3, 2018 | 02:09 AM
Busyb187's Avatar
Yes all the misfires are on the same side. I will try to make some time this weekend to take the plugs out and put some new ones. One quick question, when you say left side, you mean the pasaanger side? Also, what should the compression read?
Old May 3, 2018 | 04:05 AM
The left side is the driver's side for a North American model. See the link in my prior post for the cylinder numbering.
The engine should be warmed up prior to performing the cylinder compression test. Remove the fuel pump relay. Start the engine and let it run until it stalls. Remove the spark plugs.
Install the compression tester in one cylinder. Crank the engine at least five compression strokes (hence, ten revolutions) and record the highest reading. Repeat for all cylinders.
The lowest cylinder should be within 75% of the highest cylinder. I don't see a specific compression pressure spec in the factory repair manual. My guess is that 150 psi would be about right for a new engine.
Old May 3, 2018 | 04:17 AM
Cambo's Avatar
I'd be checking for a failed/collapsed/choked catalyst on that bank.
Old May 3, 2018 | 05:13 AM
steve_k_xk's Avatar
+1
Old May 3, 2018 | 06:18 AM
Ranchero50's Avatar
X 10,000...
That's how the OP found out mine were clogged. They then punched them out with a long rod and the misfire codes went away to be replaced with cat efficiency ones.
Old May 3, 2018 | 08:34 PM
Busyb187's Avatar
Thanks everyone for the help. Another quick question, how can I check to see if the cat is the culprit? How can I check for a collapsed or baf catalyst?
Old May 4, 2018 | 07:55 AM
Ranchero50's Avatar
Put the car on a lift or jack stands and either pull the front o2s, start the car and compare the exhaust pressure coming out of the ports or pull the muffler and mid pipe off and do the same at the down pipes. The clogged cat will have huge pressure out the o2 port and minimal out the back. You should also be able to tell from heat with an I/R gun comparing the temps before and after the cat. Magnaflow makes cat downpipes for $370 off Summit Racing. Should be OK as long as you aren't in Commiefornia.
If you like the car now, you'll be amazed once it's running on more than 4 cylinders.
Old May 4, 2018 | 02:49 PM
Busyb187's Avatar
Thank you so much. I will lift it and check the cats tomorrow afternoon. Also I put the code reader on today in the morning and now it also has code P0305 and P0442 on top of the other codes. I forgot to mention that when I first start it in the morning, it has a riugh idle then kind of evens out onve its warm. You still feel a slight misfire once warm but its hatdly noticeable. But when first started it idles pretty bad.
AJ34S
Feb 15, 2021 10:30 AM
Gblauf
Mar 3, 2013 09:36 AM
Dirkman
Aug 30, 2012 06:53 PM
SeldomJAG
Oct 11, 2011 12:21 PM
