2007 XKR Veneer around touch screen loose
Old Mar 30, 2014 | 02:05 PM
liquid-chris's Avatar
Default 2007 XKR Veneer around touch screen loose
The veneer around my touch screen was slightly bowed outward. When I pressed it back forward, I noticed it was quite loose. I can very easily pull it off, as if it is simply resting in place with no clips actually holding it in. Normal? Missing clips?
Old Mar 30, 2014 | 02:30 PM
jahummer's Avatar
Not normal, should be very tight. Can you take it off completely to check? There should be 7 metal clips, 3 across the top, 2 on each side and 2 on the bottom.
Old Mar 30, 2014 | 02:41 PM
Yes, I can pull it right off. I see slots, but unless the clips are not visable there are no clips????????
Old Mar 30, 2014 | 03:03 PM
BruceTheQuail's Avatar
Sometimes the female part of the clip (which is like a metal sleeve) gets stuck on the male part, which is on the back of the trim. If all you see is holes in the dash, then that is probably what has happened, you will find the metal things on the back of your veneer holding on to the plastic protrusions, smirking at you.
You need to wiggle the metal bits off the back of the trim and push them into the holes in the dash until they are flush. Then put your veneer back in, it should be fine.
Old Mar 30, 2014 | 03:08 PM
I just took another look. The clips are missing. Not in the holes...not on the tang on the trip panel. Might somebody have a part number the clips? Looks like I'll have to visit Jag for some replacements. Odd huh?
Old Mar 30, 2014 | 03:55 PM
jahummer's Avatar
C2P8074 - they are $.95 each
Old Mar 30, 2014 | 04:50 PM
Can that be correct? Something for under a buck at the Jag dealer?
Old Mar 30, 2014 | 06:22 PM
Ngarara's Avatar
Yeah - but the plastic bag they put them in costs $50
luc891
XE ( X760 )
Sep 15, 2015 12:30 AM
1LowCat
Sep 14, 2015 07:51 PM
texaspete
Sep 10, 2015 08:34 AM
ferraripete
Sep 10, 2015 01:24 AM
obwoodie
Sep 3, 2015 07:45 PM
