2008 XK - help upgrading Navigation/iPhone system
Old Nov 15, 2022 | 11:49 PM
  #441
tmich's Avatar
For me - all fine, not planning a return to the stock unit.
Old Jan 28, 2023 | 11:53 AM
  #442
Wes G's Avatar
Post
Originally Posted by tmich
Damn either I'm blind or I really don't have a radio antenna cable nearby... Made a huge disassembling to find it and so far not even close... Anyone with MY10 with an experience about radio antenna?! Sean W - counting very much on your suggestions.
I will plug OEM player tomorrow to check if it plays radio without a fakra plugged in to determine whether it was there and disappeared (as radio worked for me) or I need to provide an aftermarket antenna to a screen (or somehow provide AM/FM signal from an OEM antenna to a screen).
This is probably a long shot as the thread is old but Tmich did you ever figure out the radio antenna? I also have the MY10 XKR and can not find a factory cable anywhere to plug into from the head unit side.
Old Jan 28, 2023 | 12:27 PM
  #443
tmich's Avatar
No luck in here as well
Old Jan 28, 2023 | 04:54 PM
  #444
Wes G's Avatar
Thanks for the quick response Tmich. This is frustrating me as I can only pull in one FM station. Weird. I just now ordered an auto FM antenna on Amazon which hopefully will help.
Old Feb 18, 2025 | 01:57 PM
  #445
edlgreer's Avatar
My wire connector, 10 pin to 4 pin connector, is missing from my car, Is there anywhere I can get a replacement? Also, my 10 pins dont match the picture. Mine is 1 black, 2, empty, 3 white 4 blue 5 empty 6 brown tan 7 empty 8 empty 9 empty 10 brn white. I really just need to get my flashers working. Anyone know how to just hook the wires between the faceplate and the 10 pin connector so, I can get it working?
Old Feb 18, 2025 | 02:03 PM
  #446
edlgreer's Avatar
Default My 10 pin to 4 pin connector is different. How do I wire it together?
Salieri
Jun 15, 2017 12:37 AM
XXXAngelXXX
Sep 1, 2016 07:07 PM
Michaell
Aug 8, 2014 05:58 AM
Stillwaters
Mar 29, 2012 05:45 PM
