2010 XKR fluid changes
Old Jun 21, 2020 | 07:15 PM
pennstater's Avatar
Default 2010 XKR fluid changes
Was hoping to get some recommendations on fluid changes for my 2010 XKR with 65000 miles since you guys are the experts. I got the car last Oct and from what I see, the brake and power steering fluids were changed 3 years ago in addition to regular oil and filter. The car runs absolutely fantastic - what maintenance would you guys recommend at this age/mileage. Thanks so much!
Old Jun 21, 2020 | 11:52 PM
Marc Voorhees's Avatar
Jag recommends brake fluid every 2 years. After having mine tested, and seeing the results of just 22 months, in between changes, I would personally strongly suggest you follow that recommendation! 3 years seems too long, definitely want that swapped out
Old Jun 22, 2020 | 03:03 AM
I like to change ALL fluids on a "new to me" Jaguar. Regardless of what it shows in the Service History, this then gives me a known base point for future maintenance and picks up on anything which may have been overlooked.
Here's the Maintenance Check Sheet for 2010 Model Year:
Note that the recommended service interval is 15K Miles OR 12 Months - whichever comes sooner.
Old Jun 22, 2020 | 06:37 AM
pennstater's Avatar
Thanks guys. Would you have them do the transmission fluid as well.
Old Jun 22, 2020 | 10:04 AM
asb's Avatar
asb
I would do transmission fluid, differential fluid, and supercharger oil. I don't think most owners know that you need to change those things as well, and from what I understand, those aren't fluid changes the dealership would normally recommend.
Old Jun 22, 2020 | 02:09 PM
George05's Avatar
Hitting 65k miles them are a must and Another thing the service schedule dont say is The Ancillary & supercharged belts along with spark plugs need changing at 10 year OR 100k what ever comes first This car will be 10 year old in 6 month Splash the cash .
Old Jun 22, 2020 | 02:50 PM
George05's Avatar
Cost wise around $2,000 should see all work done . over here from a good indie . Transmission service £450. supercharged oil change IF taking super charger top off get the copler done and new oil in the unit £500 then both belts £300 spark plugs £300 . IF shes a keeper . worth every penny
Old Jun 22, 2020 | 04:26 PM
asb's Avatar
asb
For reference, I just got my diff fluid and trans fluid replaced at the dealer nearby, and it was just under $700 for the trans fluid and $200 for the diff fluid. Unfortunately, the indie mechanics I contacted didn't want to do the transmission fluid change.
On a related note, has anyone DIY'd the supercharger oil for the 5.0 engine without removing the supercharger? I know the location of the fill hole makes the job kind of hard.
Old Jun 22, 2020 | 05:18 PM
George05's Avatar
I forgot about the Diff oil change sure it cost under £200 . Yes sure it was only £110-145 . without checking files . its an easy job to do so i am informed . Yes i have also done a Diy on the supercharged oil change not easy on the 5l cars . sure its in the stickies or maybe some one can point you in the right direction i took photos
Old Jun 22, 2020 | 05:31 PM
George05's Avatar
Old Jun 22, 2020 | 05:34 PM
George05's Avatar
Old oil is like gunk and Real smelly . Fill drain plug /grommet is down the gap in last photo just before the blue paper towels i put in to catch any oil or in case i dropped the plug you will see it slightly protruding from allen key
Old Jun 22, 2020 | 05:39 PM
George05's Avatar
Done a search on stickies cant find the how to
Graham ?
posts . could a Moderator please add
Old Jun 23, 2020 | 05:43 AM
V7Sport's Avatar
Graham ?
I think this is the how to from George05
https://www.jaguarforums.com/forum/x...-221427/page3/
Old Jun 23, 2020 | 02:43 PM
George05's Avatar
Thanks fame at last lol
Old Jun 23, 2020 | 05:35 PM
V7Sport's Avatar
As you deserve👍
Old Apr 11, 2021 | 02:11 PM
jbmi's Avatar
Last fall I bought my 2010XK with 53K, it had a good CarFAX that showed regular service, but did not show what the service was for.
So, just to give me a base line to start with I had all fluids changed (oil and filter, coolant, power steering, brake fluid, differential, drop pan transmission and replaced a 5 year old battery, even though it still tested good.) all filters were still almost new. Everything ran about $2,200 . She runs like brand new
Old Apr 11, 2021 | 04:56 PM
George05's Avatar
Ancillary belts will be needing changed , rubber will have perished due to heat or cold
Old Apr 12, 2021 | 03:00 AM
XKRAU's Avatar
When you don't change the diff oil this is what its going to look like when it comes out. I don't think its part of the service.
Goto the 5min mark.
Old Apr 12, 2021 | 05:51 AM
MarkyUK's Avatar
My diff oil was fine a 52k BOT720b if I remember rightly I paid £25 for 2 x 1l bottles of Ebay, the dealer price is I think double that, quite easy to access and defo a DIY , but as my Indy only charged me half an hours labour at £65ph plus tax (when added to my service) it was a no brainer at less than £38/$52
Old Apr 12, 2021 | 08:58 AM
80sRule's Avatar
Mine were squealy coming out of winter storage one year and despite only have 55k on the car in early 2019, I replaced them. The SC belt was the squealy one but I just did both since I didn't know if they were original. No squeals! I like every six years for serpentine and sc belts; I run TBs a little longer and more to mileage (although not applicable here since the Jag V8s are timing chain).
rexus31
Jun 12, 2020 11:08 AM
Russ9898
Jul 26, 2019 10:26 AM
zray
Aug 27, 2018 08:18 PM
Bruce H.
Aug 15, 2013 01:29 PM
pomosv
Apr 24, 2012 12:55 AM
