2012 xkr screenwash bottle question
Old Apr 14, 2021 | 02:09 PM
bigbaddog's Avatar
Default 2012 xkr screenwash bottle question
When I fill the screenwash on my 5.0 xkr instead of the filler tube filling to the brim it overflows at a much lower level all over the floor. This is my first x150- is this normal or was my car built on the Friday afternoon shift?
Old Apr 14, 2021 | 02:31 PM
envincibal's Avatar
I too have an 2012 XKR with the same issue... dropped it off at my indy yesterday for that and various fluid changes. I don't expect to hear back from him until possibly Monday and will let you know what the issue was.
Old Apr 14, 2021 | 04:07 PM
fxdwg's Avatar
When I look a the part- #C2P21376, the only leak points are through the fittings the pumps go through the tank or the fluid level sensor through point. They are all very low in the tank. If your tank fills more than about 1/4 full and then leaks, it may have a crack in the tank.
Old Apr 15, 2021 | 12:20 AM
kj07xk's Avatar
My ‘07 does that too. The filler pipe to reservoir connection is not sealed.
Old Apr 15, 2021 | 12:43 AM
MarkyUK's Avatar
Mine fills to the brim with no leaks, always ensure I do it before I go in for a service so they'll not charge me £3 for screen wash top-up....tight git that I am
Old Apr 15, 2021 | 02:17 AM
Usual cause of spillage is the seal between the filler neck and the reservoir (see item 9):
The list price on C2P11182 is $2.25.
Old Apr 16, 2021 | 06:01 AM
guy's Avatar
guy
you get charged for the fillup??
Old Apr 28, 2021 | 01:57 PM
bigbaddog's Avatar
Thanks Graham I'll order that seal as its so cheap before I even strip out the liner to look.
Old Apr 28, 2021 | 02:49 PM
It's usually from the the filler neck to reservoir seal but it can sometimes be from either of the grommets on the two pumps.
Old Jun 20, 2021 | 12:05 PM
bigbaddog's Avatar
On taking the filler neck out (this whole job was done from the top, saving wheel and arch liner removal) the original seal had been crushed by the factory on 'fitting' and looks like it has leaked from day 1. The seal was just over £2 from jaguar and fitting was easy from the top- I used a touch of silicon spray on the new seal and pushed it into place using the handle end of a screwdriver- if you had small hands you could just about get them into the recess. About 10 minutes start to finish.
Thanks for the help
Old Jun 20, 2021 | 03:23 PM
Cee Jay's Avatar
Weird it got crappy, mine is perfect.
frogeye621
Jun 25, 2023 07:32 AM
DublDwn
Nov 5, 2017 09:08 AM
KaaNo
Apr 8, 2016 07:52 PM
xpk1x
Jun 23, 2013 08:43 PM
