AC blower fan help
Old Nov 13, 2019 | 08:30 AM
gkubrak's Avatar
Yes I found it here:
https://www.jaguarforums.com/forum/x...e-%245-184627/
My plan is to check the voltage at the junction box. 12 V at the junction box and 10.4 V at the motor means there is a higher than normal resistance on the ground line, going to the module (AKA bad module).
Old Nov 13, 2019 | 09:38 AM
gkubrak's Avatar
Bet you guys can't guess what that black stuff is in my pictures above....
Old Nov 13, 2019 | 12:30 PM
kj07xk's Avatar
So many possibilities:
A. Toast crumbs from breakfast, as you obviously did this on the kitchen table?
B. Remains of the mouse that had crawled in there before you fired it up?
C. Dust from the motor brushes?
Old Nov 13, 2019 | 02:41 PM
Cee Jay's Avatar
I will guess (seriously) that it's grindings from the heater housing.
Old Nov 13, 2019 | 03:31 PM
gkubrak's Avatar
If you saw the rotor you might have guessed otherwise.
Its carbon build up from an exhaust leak I noticed a few weeks ago.Visually confirmed it the other day. I thought the smell was from my catch-can tubing, but its actually exhaust leaking from where the CAT and header flanges meet. That's a lot for only a few weeks of leak, huh?
Do they make air filters that would catch exhaust??
Another issue to fix smh....
Anyway i'm still looking at the module as the failure here. Since the motor has been refurbished.
Old Nov 13, 2019 | 03:33 PM
gkubrak's Avatar
I wish it was any 3 of those lol
That would be a pretty lame kitchen table and some burnt toast. Neither are my style.
Old Nov 13, 2019 | 05:28 PM
kj07xk's Avatar
Wow. Ok, hope you are now driving with the windows open until that is fixed, no need to tox yourself with CO.
Old Nov 17, 2019 | 09:31 PM
  #28
gkubrak's Avatar
Yeah tell me about it. Turns out the flange nuts on both sides were loose. Like ... unscrewed with my fingers loose. Guess I didn't tighten them enough when I changed the CATs. Tightened them up and no more exhaust leak. Exhaust note sounds normal now too. Glad it was just that.
As for the blower, I traced it back to the module and replaced a fuse per the other thread.
Old Jul 25, 2021 | 01:47 PM
JagXKR2009's Avatar
Default Replacing 2009 XKR HVAC blower motor
Replacing 2009 XKR HVAC blower motor.
Guys, I saw some pretty high $$ values kicked around for a new motor C2P8256. Partsgeek.com has them for 42 - 48 USD new with free shipping! Best of luck, Lloyd
Old Sep 24, 2021 | 07:32 PM
  #30
McJag222's Avatar
Thanks for the video Sam - my blower started squeaking earlier on.
GoNavyMike
Nov 16, 2015 12:34 PM
carlprs
Oct 7, 2015 07:45 PM
blipner
Jul 13, 2013 02:29 PM
A Dopo
Feb 7, 2013 09:08 AM
BobWeeks
Jul 19, 2012 08:43 AM
