Adjusting the Seat for exit mode
Is there a way to set the exit mode for the seat and steering column at the same time? I know you can set this up for the steering wheel column exit knob on auto. I need for the steering wheel to go up and the seat to move all the way to the back and down to the floor. I am six one and need the leg room to exit. Can this be set up when the car's engine is turned off then this activates when you exit the car?
Very simple solution..
never thought of that....
but seat already back and lowered for me so I don't need any alterations
I believe that the setting you are referring to only adjusts the steering wheel when the setting on the side of the column is adjusted to automatic. However, I'm kind of hesitant to use it in the auto setting for fear of wearing out the motor on an older car. It already makes some creaking noises when the steering wheel adjusts. I'm a small guy (5' 5") and I do need the steering wheel to adjust when getting in and out.
wj
Maybe it’s just mine, but my seat is so slow, I’d die of old age waiting for it to move back before exiting. And it’s absurd, or maybe just mine, that I have to hold the memory button down the entire time it is adjusting to the memory position.
Seat modules have a reputation for failing, especially with a weak battery . If the above didn't help, you might need to reprogram that seat module or get a new one.
See: Driver seat not adjusting.
Good luck!
Stuart
Bacardi 151
Nov 20, 2013 12:40 PM
