Air Bag Light
Old Mar 24, 2018 | 07:34 PM
Arzie's Avatar
Angry Air Bag Light
Greetings all. I've got a 2008 XK Convertible. The air bag light stays lit on the dash. Anyone have any suggestions on a quick fix?
Old Mar 25, 2018 | 12:48 AM
sov211's Avatar
A quick fix, no. A common cause of this symptom is a failing "clockspring" mechanism in the steering column - and this is not an issue limited to Jaguar's. The fix: replacing the clockspring, which is a dealer job.
Old Mar 25, 2018 | 04:33 AM
steve_k_xk's Avatar
The air bag can be tricky to remove as there is two clips holding it in place (I've got a write up on how to remove it)
From there you'll need a 10mm Allan key and fairly large breaker bar
Old Mar 25, 2018 | 08:56 AM
Sean W's Avatar
Start with the codes. Have them read. You're simply going to be taking pot shots @ fixing it without the codes.
Old Mar 25, 2018 | 03:17 PM
steve_k_xk's Avatar
Should have mentioned that
Yes pull the code up first
Old Mar 25, 2018 | 05:07 PM
peterv8's Avatar
All depends on which airbag is malfunctioning, need the codes!:-)
Old Mar 26, 2018 | 09:08 AM
khsjsilver's Avatar
I had the same problem. Not a quick fix, not inexpensive. Brought it to my local independent Jaguar guy and he couldn't fix it. Brought it to the Jag Dealer. The Code was a B-0002-1B, drivers frontal stage airbag circuit open. The repair was to replace "cassette reel/module". Don't know what this actually meant, but the repair was $510! Works fine now.
Ken
Old Mar 26, 2018 | 12:46 PM
sov211's Avatar
Ken
The "cassette reel/ module" is the "clockspring" which I indicated as the source of the problem in my response above ( #2). The OP will find this to be the part that needs replacement!
dsd's Avatar
dsd
Fuel and AirBag. Two things I don’t mess with :-)
If you are at all hesitant, take it in.
Old Mar 27, 2018 | 11:09 PM
LoudHogRider's Avatar
I’ve got a quirk with my passenger seat wiring that can cause the air bag warning to illuminate. It has to do with the wiring under the seat. Mrs. LHR is under strict instructions NOT TO MOVE THE DANG SEAT! It’s a flawed, but functional approach ... for now.
Old Apr 2, 2018 | 04:29 AM
HaydenS's Avatar
When I bought mine, it also did this for weeks. Eventually I found a position for my steering wheel in which the clockspring didn't mess with this. I also got it checked by a dealership to make sure it wasn't an actual issue of course!
Old Apr 2, 2018 | 01:18 PM
sov211's Avatar
So the cause of the airbag light illuminating on your car was a faulty clockspring...yup. The original poster seems to have disappeared without telling us what the problem was found to be. Frustrating. An acknowledgement of the suggestions made in response to questions is an expected courtesy, no?
Old Apr 2, 2018 | 04:22 PM
pwpacp's Avatar
Maybe he is still pulling his hair out......if not, I agree just a bit rude.
I'll thank Y'all for him then, it an interesting read.
The Ricker
Jan 2, 2016 11:12 AM
Metapoint
Aug 13, 2008 10:27 PM
n17gary
Feb 1, 2008 10:25 PM
n17gary
Sep 9, 2007 04:15 PM
