Airbag Light On
Old Nov 15, 2023 | 07:47 AM
Sailor Mike's Avatar
Default Airbag Light On
This is a continuation of the thread 'Airbag light on and no response with Navigation' which was considered Resolved once the navigation problem was sorted.
I took the car into a local general workshop and they put their box of tricks on the car and found the problem. I didn't get the code number from them but I was told that the problem originated in the passenger seat belt tensioner and was likely to be a loose connection. The light was reset. I think the fault may have come up prior my taking delivery of the car and while the previous, somewhat tired, battery was in use. Anyway we'll see what transpires in the coming weeks. The next problem is easy, though costly. 8 year old tyres to be replaced with Michelins next week.
Old Nov 15, 2023 | 09:51 AM
Sean W's Avatar
Please have them give you the code and post here until you're certain it's resolved.
Old Nov 15, 2023 | 11:27 AM
Default Fault code
It's too late. The guy spent 10 minutes on the job, didn't record anything and can't remember which is not surprising. It's only a small local garage who did not even give me a bill, This is rural Spain.
Sorry.
Old Nov 15, 2023 | 01:00 PM
tmich's Avatar
I would suggest to start looking for a new tensioner. Had the same thing and need to replace one. No more codes afterwards.
Old Nov 15, 2023 | 04:44 PM
Sean W's Avatar
OK thanks. I asked for codes because wasn't sure if you mechanic said tensioner or pretensioner. Does the belt retract slowly, is it "loose"? Have you tried pulling it out fully to make sure it isn't twisted? I would consider that and also give the belt a good cleaning. If that doesn't work, yes replacing would be the option.
Old Nov 16, 2023 | 12:04 AM
tmich's Avatar
In my case this was the second part (where you put the belt) /sorry for lack of proper English/
Old Nov 16, 2023 | 05:20 AM
Where is the tensioner located, in the reel or the buckle (the part next to the transmission tunnel) or is there one in each? I'm interested so that I can sort out a supplier just in case.
In reply to Sean, the problem seems to be fixed although time will tell. I saw the technician pulling the belt out a few times during his checks but I have tried it myself and all seems good to me. I'll give it a clean anyway when I next wash the car. Unfortunately my Spanish isn't good enough to pick up the difference between tensioner and pretensioner particularly in the Andalucian dialect. I do suspect the old battery though. It would start the car after being on the Ctek but after a day or two the voltage was well below 12v so not retaining the charge. Now there is a nice new Varta in place with the Ctek permanently wired in.
Last edited by Sailor Mike; Nov 16, 2023 at 05:25 AM. Reason: added language comment
Old Nov 16, 2023 | 06:07 PM
Sean W's Avatar
@Sailor Mike the pretensioner is the receptacle on the trans tunnel side and there are pyrotechnics involved. Pretensioner's tend to fail before tensioners (my two cents) as they fill with crud over time. If the belt is moving freely and retracting with good return spring, it could be either side. At any rate and take it for what it's worth, these parts are best just replaced. I'm pretty sure the tensioner has no repairable parts sold separately. You have to replace the unit. Same with the pretensioner and for safety reasons, replacement for me is the only option. I wouldn't be adverse to buying used on eBay myself but that's a judgement call and having only the information you gave, I would start by replacing the pretensioner.
Old Nov 20, 2023 | 06:54 AM
fritzthecat's Avatar
I’ve experienced a similar problem, see my post here:
https://www.jaguarforums.com/forum/x...6/#post2663021
stevis05
Jun 24, 2023 12:23 AM
sashoivanov78
Feb 1, 2014 03:12 PM
rsmartin
Jul 21, 2013 12:24 PM
spencerikin
May 12, 2013 11:14 AM
pnyklr
Feb 7, 2010 11:51 AM
