Alcon Brake Rotors
Old May 25, 2022 | 02:37 PM
JaguarXKR's Avatar
Default Alcon Brake Rotors
Hi All,
I purchased an "aftermarket reproduction" Alcon style brake rotor from SNG Barratt. The rotors showed up today and I noticed the crescents are not drilled all the way through. Are the OEM rotors the same way?
See below! Thanks!
Old May 25, 2022 | 03:10 PM
Cee Jay's Avatar
Same Same
Old May 25, 2022 | 07:30 PM
Knomad's Avatar
On the OEM rotors I got from Suburban Autoparts, the crescents are cut through. They were actually Jaguar part numbers.
Old May 25, 2022 | 09:10 PM
JaguarXKR's Avatar
Do you have a picture by chance?
Old May 25, 2022 | 10:10 PM
JaguarXKR's Avatar
I just found a picture of the OEM rotors. It even has the "Jaguar" lettering if you look closely.
From the picture, it is not cut all the way through, same as the remakes.
Old May 26, 2022 | 11:05 AM
Stuart S's Avatar
OEM Jaguar Alcon rotors are grooved, and do not go all the way through the disk.
I know because my 2009 XKR Portfolio convertible has the Alcon Performance Brake Package, a $5,000 option, and am still using the original rotors. A few years ago, I replaced the pads only, without resurfacing the rotors because they were still in good shape.
I have a brand new set of Centric "Alcon" rotors and Brembo ceramic pads that I'll use when it's time for new pads. See:
Alcon Rotors Cheap
Unfortunately, it appears that they're sold out.
Brembo Ceramic Pads for Alcon Rotors
Old May 26, 2022 | 12:56 PM
gkubrak's Avatar
I purchased the same ones twice now. Only differences I noticed:
1. The shape of the grooves is different
2. There is no notch on the aftermarket ones like there is on the OEM ones - even though the manufacturer specifies they ARE machine balanced
Other than, that they are a great alternative for the super expensive OEM ones.
Old May 26, 2022 | 03:13 PM
Knomad's Avatar
I guess I was lucky. I ordered all 4 rotors for my 2008 XKR Portfolio on line from Suburban Auto Parts on 2/10/2022
  • Front Left: C2P10565
  • Front Right: C2P10564
  • Rear Left: C2P10563
  • Rear Right: C2P10562
They actually shipped from Troy NY Jaguar in Jaguar packaging.
They all looked exactly like the originals and all the crescent grooves were cut all the way through.
Total cost of the 4 rotors was $3,123.29
Old May 26, 2022 | 09:00 PM
Stuart S's Avatar
Are you certain that the crescent grooves go all the way through the disk? If so, they're not the same as the original Alcon rotors.
And they might not be genuine. See:
Alcon Crescent Grooved Rotors Rotors
Old May 27, 2022 | 07:32 PM
jahummer's Avatar
Stuart's correct. Drilled go through the braking surface to the cooling vanes at the core, grooved discs never ever go all the way through, typically machine grooves are just lightly deeper than wear thickness, for example Alcon front discs start at 36mm and are considered worn at 34mm, with the grooves just slightly deeper.
Old May 27, 2022 | 07:38 PM
jahummer's Avatar
All the Alcon rotors I've had were grooved exactly the same way and notched. The grooves on the SNG supplied in the OP's post do not match OEM and having spoken with SNG, I was advised they were aftermarket supplied to only match OEM but were not OEM. The Centric sourced ones did not say Jaguar however Centric's buyer insisted their's came from the same OEM manufacturer's as Jaguar's. As far as I know, like many parts, none were ever actually manufactured by Alcon.
Old Jul 1, 2022 | 07:00 AM
JaguarXKR's Avatar
Does anyone know if these are painted or replaceable pieces on the Alcon rotors? One of my fronts and half of one in the rear are gone.
Old Jul 1, 2022 | 09:05 AM
jahummer's Avatar
They’re painted.
Todd Wiens
Jun 29, 2021 10:23 PM
Todd Wiens
Jun 28, 2021 02:10 PM
swayne
Aug 8, 2018 01:35 PM
Robinb
Apr 24, 2014 11:31 PM
Fastlane'scat
Feb 9, 2014 06:27 PM
