Any electrical experts here?
Old Jul 11, 2014 | 08:47 AM
M6XKR's Avatar
Default Any electrical experts here?
I installed a set of Adamesh LED tail lights on my 2007 XKR, I am not sure this is a factor in the problem I am experiencing, but I do not have the stock tail lights to swap back in to rule it out.
Problem: Occasionally when driving the car's dash board will display a "indicator/bulb failure" for the Entire Driver side of the car. (Driverside Headlight, fender/sidemarker, and taillight) all at the same time. The weird part is, I am 95% sure the lights are all still fully functional as I have got out to check or have seen them working in the reflection of other cars.
I keep the car on a CTEK charger so the battery should not be the issue, although the battery is a few years old.
Any ideas what might be causing this issue or a good way to find the route cause? possibly a bad ground?
Old Jul 11, 2014 | 08:51 AM
jimbov8's Avatar
Very strange.
I would start by going over exactly what you did and then checking the grounds as well.
It could be a loose connection, hopefully so.
Old Jul 11, 2014 | 08:53 AM
M6XKR's Avatar
The hard part is I swapped these lights out right after I bought the car, so I don't know if this was an issue before or after the LED light install.
I plan to go through the grounds and connections thoroughly here soon. Maybe swap the blade style connectors on the LED kit with solder.
Old Jul 11, 2014 | 08:57 AM
WhiteXKR's Avatar
I agree, check and redo the connections first. If you still have issues, contact Geoff at Adamesh. He will go to the manufacturer for answers if necessary.
Adamesh now carries my Remote Top Kit. If a customer ever has a question he always contacts me to assist.
Old Jul 11, 2014 | 09:01 AM
M6XKR's Avatar
Great, thanks for your replies. I will go over all the connections and report back. I might not be able to get to this for a week or so. But I will reply with my findings.
Thanks,
Mike
Old Jul 11, 2014 | 09:31 PM
Stuart S's Avatar
I installed a set of Adamesh LED tail lights on my 2007 XKR ...
Mike,
I believe that when Adamesh first introduced their LED tail light conversion kit they used resistors to compensate for the lower resistance of LEDs, but had problems with the "indicator/bulb failure" warning. The later version replaced those resistors with light bulbs to equalize the resistance and eliminate the warning.
After you've verified all the connections, if you still have the "indicator/bulb failure" warning you may want to check and make sure all the resistors or bulbs are OK and haven't burned out.
If everything checks out OK and you're still getting the warning, try reinstalling the lights following the instructions posted by georgekale - see the link to his .pdf instructions in his post #51 in this thread: https://www.jaguarforums.com/forum/x...s-36907/page3/
I haven't done the conversion, but thought about doing it a while ago. Still procrastinating.
Stuart
Old Jul 12, 2014 | 09:01 PM
paintfiend's Avatar
Your "smart" flasher unit flashes twice as fast (or keys the warning text) to advise you that one of the bulbs is out...or you might not know it was out. LED units draw so much less current the flasher unit sees the lower current draw as one of the lights (incandescent) being out. The solution is to add the resistor circuit in parallel with the lamp circuit to raise the current draw (which seems counter productive since that's half the reason I switch to LEDs) or find a flasher unit that has a lower threshold.
Old Jul 14, 2014 | 10:05 AM
M6XKR's Avatar
Originally Posted by Stuart S
Mike,
Stuart
Thanks for that link, I don't think any of the bulbs are burnt out as the issue appears to be intermittent. However I think it might be a good idea to build this resistor circuit and eliminate the cheesy bulbs that you have to hide back behind the trim. It looks like a pretty simple build too.
Originally Posted by paintfiend
Your "smart" flasher unit flashes twice as fast (or keys the warning text) to advise you that one of the bulbs is out...or you might not know it was out. LED units draw so much less current the flasher unit sees the lower current draw as one of the lights (incandescent) being out. The solution is to add the resistor circuit in parallel with the lamp circuit to raise the current draw (which seems counter productive since that's half the reason I switch to LEDs) or find a flasher unit that has a lower threshold..
Thanks, I was unaware of this smart flasher unit, I am guessing the resistor circuit would be an easier/cheaper solution to try first?
Thanks for both of your replies.
Old Jul 14, 2014 | 01:17 PM
paintfiend's Avatar
The resistors would be the cheapest. I'm not aware of an alternate flasher unit that works. I actually ran across this problem working on a motorcycle. Isn't technology wonderful?!
04Xjrsteve
May 7, 2019 04:06 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
magmedia
Sep 28, 2015 09:49 PM
