Audio plug
I recently bought a 2007 Jaguar XK and have a question about the audio recepticle and switch inside the center console. See attached picture. Does anyone know how this works?
Plug an audio source into the plug hole using a 1/8" stereo cable, and the other end into the audio source. Have the car audio turned, turn on that little switch, play the device. If nothing happens, check the Audio section on the TSD and change the source until something happens. Maybe on "AUX" or something?
That doesn't look OEM, I've never seen that before. Mine has nothing there.
Course, I have a '10 so maybe that's the difference?
I do know that some cars have an audio input inside the glove box, so maybe that one was moved on your car?
I think Cee Jay more or less nailed it. The only thing, the switch might be used for switching between the 1/8 jack and something else, like the factory cd changer possibly? If that is the case, you might have to have that selected as the source. The only thing that throws me a bit is that doesn't look like a double pole type switch, but I could be wrong. With out seeing the back it is tough to know.
Did the 2007 model still have an antenna? Maybe it is like the switch many X100 owners use to stop the antenna from going up when not using it.
That’s a sweet set up!! I’m interested in this as well- can you find out what it does and what was done?. I was attempting to add an auxiliary input but the antenna on the back of the radio isn’t a big Motorola, it’s small. Anyone know of an adapter to the larger one or a plug and play aux input?
H20boy
42
May 21, 2022 02:22 PM
jjsaustin
Dec 13, 2019 08:50 PM
Teck4Jag
Feb 11, 2017 01:55 PM
daboss085
Jul 11, 2012 05:46 PM
jmalagon42
Jan 5, 2011 05:49 PM
