Bored
Old Apr 8, 2025 | 11:50 AM
wymjym's Avatar
Default Bored
Getting things together for a little front suspension work, I was curious what a quick pass on the buffing wheel would do to the upper control arms I’ll be using.
(thanks again Mike for the donation)
Shiny!
wj
Old Apr 8, 2025 | 05:32 PM
guy's Avatar
guy
pretty! should probably clear coat them ;-)
Old Apr 8, 2025 | 05:59 PM
Stuart S's Avatar
Better still, tell your wife how beautiful her fingernails look and ask her to do it.
Old Apr 8, 2025 | 08:26 PM
bill_jags's Avatar
I completely understand the urge to do something to the Jag just because you can. Last week I put a matching burl overlay on my 2007 Jaguar cupholders. Being retired does leave time on our hands.
Old Apr 8, 2025 | 08:42 PM
Stuart S's Avatar
The ultimate mod ...
Old Apr 8, 2025 | 08:56 PM
bill_jags's Avatar
I like the button. Here is my burl ashtray that I put in front of the shift knob ( regular ashtray is covered with a little shelf).
Old Apr 9, 2025 | 08:32 AM
neven.gordic's Avatar
@wymjym where did you got the Strut/Spring Shock Mounts from?
Old Apr 9, 2025 | 09:38 AM
wymjym's Avatar
in the USA
https://www.ebay.com/itm/314623695037
wj
Old Apr 9, 2025 | 11:59 AM
HealeyJag's Avatar
Where did you buy it from?
Old Apr 10, 2025 | 11:44 AM
wymjym's Avatar
if this is for me, the above link takes you to the ebay vendor.
wj
Old Apr 14, 2025 | 07:08 AM
fritzthecat's Avatar
Originally Posted by wymjym
Those say they’re for an XJ. Are you sure they’re the right ones?
Old Apr 14, 2025 | 07:46 AM
wymjym's Avatar
From everything I have read, yes.
I haven't had an opportunity to install as yet, so can't say for certain...but once again, have read multiple places that they are the ones.
WJ
Old Apr 17, 2025 | 08:41 AM
WJ
@wymjym, I shoulda responded sooner, but got busy.
If you've already gotten the parts and done the job, then ignore this post. If you haven't, read on...
My car is an '09 Portfolio convertible. I found that the mount part number for the ragtop is different than the coupe. Not sure why, seems weird that it would be that way, but I wasn't about to try anything that wasn't spec'd out. The isolator part number is C2D16903. The mount is C2P23038. If you're sure the eBay ones are correct, then $49 is an unbelievable price for the set. I got the isolators from Harper Jag for $104.20 each and the mounts from Jaguar of LA for $70.10 each, which adds up to a whopping $348.60 for the entire set. You may have found the best deal ever - if they're the right ones.
I posted a how-to on this job, too, but since you have all that stuff and the A-arms disassembled already, that might not be as helpful, but here's the link, anyway:
Front Strut Leak? - Page 2 - Jaguar Forums - Jaguar Enthusiasts Forum
HTH,
Rick
Old May 10, 2025 | 01:54 PM
wymjym's Avatar
Bored no more!
Looks aren’t everything when it comes to evaluating some components. I wanted to replace my original upper control arms due to 125K miles of usage and the fact that the ball joints had been exposed to the elements for many years.
While working in that area I thought the ‘used’ (65K mile) xkr struts could use new mounting cushions.
So here are the pretty parts
Here are the ones I removed
After my fellow Jag enthusiast and I finished up we were both tired and happy that this project was done.
The results: I can barely feel any changes what so ever. The ugly 125K ball joints didn’t display much play at all. The original shock cushions were ever so slightly compressed more that the new ones we installed.
The job is completed and I’ll rest up before getting into replacing the front seat leather.
Wj
And yes, these shock cushions are a proper fit for the xk-xkr. $46.00 usd for both, shipped (pre tariff) is a far cry from oem pricing!
Old May 12, 2025 | 07:52 AM
@wymjym , I’m truly happy that the parts worked well for you. Even though it means I spent $300 too much! Aaaaaahh!!!
I guess in the future I need to do better research on parts cross match.
oldole
Apr 9, 2025 03:33 AM
pnwrs2000
Nov 19, 2015 09:53 AM
jjbuck2
Nov 4, 2015 03:04 PM
SD96XJ6L
Oct 6, 2015 07:54 AM
Noxparadise
Jun 15, 2014 06:40 PM
