Can I prevent the A/C drain?
Old Jul 15, 2015 | 08:09 AM
orange's Avatar
Default Can I prevent the A/C drain?
Hello all,
1) Is it possible to shut the airconditioning fully off in a 2007 xk?
2) Do the fans still work in this mode? So I can heat the car if needed (in my other car, I always turn the a/c off, but when it's cold for example, the fans can blow hot air, but with the a/c turned off).
The reason I'm asking is this: I don't like airco, it makes my throat hurt And in every other car I have ever owned, I almost never used the airconditioning.
If the a/c can be turned off in an xk, but still blow hot air when it's cold, I can also prevent the dreaded a/c leak.
Thanks !!
PS. English is not my first language
Old Jul 15, 2015 | 08:25 AM
MoscowLeaper's Avatar
Sure you can. On a climate settings screen touch "econ" button and it will turn an A/C off.
Old Jul 15, 2015 | 09:08 AM
orange's Avatar
And this shuts the airconditioning completely off? That's easy
And the fans still work in this mode (blowing warm air if needed)?
Old Jul 15, 2015 | 10:03 AM
Exactly so. A/C off, heater and blower continues to work.
Old Jul 15, 2015 | 01:59 PM
orange's Avatar
Thank you!
Old Jul 15, 2015 | 02:11 PM
RedRider48's Avatar
Originally Posted by orange
Thank you!
Yep, I do this on my '08. Easy Peasy!
Old Jul 15, 2015 | 03:13 PM
jagtoes's Avatar
I haven't checked the OM but in most modern cars when you turn on the defroster the AC also turns on. You may want to check that.
Old Jul 15, 2015 | 05:15 PM
Ngarara's Avatar
From the manual section on Windscreen defrost and demist:
Air conditioning switches on automatically (to dehumidify the air) and cannot be deselected.
Old Jul 16, 2015 | 07:31 PM
Lothar52's Avatar
Originally Posted by ngarara
from the manual section on windscreen defrost and demist:
party poopa!!
Old Jul 17, 2015 | 05:12 PM
Ngarara's Avatar
Just the fax, ma'am...
Old Jul 19, 2015 | 03:37 PM
orange's Avatar
These aren't the droids you're looking for?
Old Jul 21, 2015 | 10:14 PM
DpezXK8's Avatar
You can select the defrost vents in econ mode but may not prevent window from fogging up as it doesn't pull the humidity out.
In the winter I don't see that being a problem but on a rainy humid day it is a must.
RaceDiagnostics
Apr 4, 2016 04:00 PM
dan102877
Sep 29, 2015 06:47 PM
oldjaglover
Sep 29, 2015 03:27 PM
42Ajd
Sep 26, 2015 07:04 PM
