Clicking from starter - RESOLVED
Old Sep 9, 2021 | 09:31 AM
Mikehill596's Avatar
Default Clicking from starter - RESOLVED
Once again my car is clicking from the starter and not starting. Battery is showing fully charged, the clicking persists so I'm assuming starter solenoid is okay. Any quick tips? (In currently stuck on a petrol station forecourt)
Last edited by GGG; Sep 18, 2021 at 01:37 PM. Reason: Add "RESOLVED" to thread title
Old Sep 9, 2021 | 09:51 AM
Usually a symptom of a partially discharged battery.
If you are absolutely confident about battery condition and state of charge then loose ground lead from battery to stud or power lead to solenoid are next in line.
Old Sep 9, 2021 | 09:58 AM
Cee Jay's Avatar
If all else fails.....
HARD RESET!!!
Old Sep 9, 2021 | 10:04 AM
HARD RESET!!!
So disconnect the battery and touch the leads?
Old Sep 9, 2021 | 10:30 AM
Cee Jay's Avatar
Yes
Old Sep 10, 2021 | 03:22 AM
Progress ...........?
1. started
2. still stuck on the forecourt
3. traded for an I-Pace
Old Sep 10, 2021 | 06:55 AM
jons's Avatar
4. purchased a diesel F-Pace so you can tow it to the shop yourself
Old Sep 18, 2021 | 01:23 PM
Sorry for the slow update! It was a grounding issue in the end!
What a P.I.T.A
Old Sep 18, 2021 | 01:31 PM
Cee Jay's Avatar
I'm glad I live in the desert, low humidity and no salt makes for a corrosion-free life. (so far)
Old Sep 18, 2021 | 01:39 PM
What a P.I.T.A
Mike,
Thanks for coming back with the result.
I've added "RESOLVED" to your thread title.
Old Sep 18, 2021 | 01:40 PM
Thanks, still getting used to Forum etiquette!
Old Sep 20, 2021 | 08:39 AM
gkubrak's Avatar
Which ground?
Old Sep 20, 2021 | 10:02 AM
jahummer's Avatar
What a P.I.T.A
I had the exact same issue a few years ago. Clicking starter turned out to be a loose ground near the battery (not the battery).
Old Sep 22, 2021 | 08:37 AM
gkubrak's Avatar
Funny, my jeep just had the same issue. Starter clicked but wouldn't crank.
Replaced starter (it was in bad shape anyway), cleaned some contact points, and it started up.
A week later, wouldn't start again. Cleaned out some grounds, battery terminals, etc... and it started up.
2 days later, wouldn't start again. Removed and bench tested starter... passed. Cleaned 2 more grounds (for the ECU this time), and it started up.
We will see how long this lasts!!
Old Jan 14, 2022 | 07:08 AM
guy's Avatar
guy
Yes, these maintenance items need be tended to…. And on the topic of a need for a booster, I don’t subscribe. Just make sure your car battery is in good condition. Like others, I’ve never been stranded by a dead battery. Of course, I replace it as opposed to play with it, when its time.
Old Jan 14, 2022 | 01:13 PM
Stuart S's Avatar
What a P.I.T.A
I closed my eyes to visualize your position and now wish I didn't. Ouch!
Old Jan 15, 2022 | 11:09 AM
panthera999's Avatar
Folks forget that there's a sequence of interlocks and switches necessary to crank the car.
Among others, immobilizer issues can include invalid key status (and other similar security issues), incorrect brake switch status, incorrect transmission switch status and others. it's an "AND" function.....
It helps to have a code reader that has access to live switch data. Simplifies the elimination of contributing conditions.
racerxf12004
E type ( XK-E )
Sep 26, 2021 06:20 PM
cityboy
Apr 27, 2021 11:11 AM
Bigg Will
Sep 29, 2017 02:26 PM
yardbird
Apr 4, 2017 07:10 AM
xjrwithproblems
Aug 6, 2010 07:04 PM
