Convertible Top
Old Jul 9, 2022 | 09:14 AM
Klaus0401's Avatar
Default Convertible Top
I want to open it, I must press the roof for the first cm by hand,after 3cm it works, normally. I close the roof and the last step, it fall down.
I checked the screw in the midlle of the roof but no way.
Anyone solved this fail? Pics?
Old Jul 9, 2022 | 09:54 AM
Cee Jay's Avatar
A sticky seal to the roof where it hits the top of the windscreen support?
Low on hydraulic fluid???
Old Jul 9, 2022 | 11:23 AM
Stuart S's Avatar
Forum member WhiteXKR (Steve) is the expert on everything about the convertible top. He's the inventor of the Convertible Top Remote Control with Rear Window Controller, which is what the factory forgot. See his advice in these threads:
Convertible Roof Not Working
Convertible Top Not Working 2
Convertible Top Reset
Good luck!
Old Jul 9, 2022 | 11:25 AM
Klaus0401's Avatar
New hydraulic fluid, the first, I did.
Old Jul 9, 2022 | 11:39 AM
Klaus0401's Avatar
Thanks a lot. I searched for the issue, but didn't find it.
First, I thought the problem are in the mechanic, I knew it from older convertibles.
Old Jul 9, 2022 | 11:41 AM
NickG's Avatar
Default Ditto
i have exactly the same issue on my 2007 XK. Was told pump needed changing but I have my doubts! I’d love some sensible advice!
Old Jul 9, 2022 | 11:50 AM
Klaus0401's Avatar
Jaguar Service told me the same by my XK8. But after changing the fluid, 3 or 4 times, so the waste went out of the valves, the top went nearly, like new.
Old Sep 15, 2022 | 01:15 PM
slash32487's Avatar
i have the 2006 - 2015 Jaguar XK & XKR (X150 series) Convertible Top SmartKey Control Module from thejagwrangler never used if anyone is interested in the marketplace
Old Sep 18, 2022 | 01:41 PM
sbolinha's Avatar
I am having an issue with the top not operating at all. I recently purchased the XK 2010 MY second hand. The roof never worked for me.
I have done already multiple test sessions. In some checks, the pump worked to pressure the tonneau bow to close it fully, so the motor and hydraulic pressure seems to work.
I did all the newbie checks: reset windows multiple times, multiple minutes, Check proper luggage separator latching. Remove RJB fuse F8 for half an hour, etc.
I connected to SDD to check the output of the sensors, The top latch sensors respond well, depending on mechanically latching the top latch using the allen key.
I get some DTCs on some bow sensors (open or short circuit), so my next checks need to go there:
FTCM B107F - Tension bow valve 2 - fault type 15 - circuit short to battery or open
FTCM B1080 - Tension bow valve 3 - fault type 15 - circuit short to battery or open
FTCM B1070 - J_14229 - Fault type 31 - Frequency modulation/pulse width modulation failure - no signal
Another issue: the quarter rear windows are fully closed. Whatever operation on the top, they do not go down mor move at all. Possibly the power supply to them is cut.
I would need to dismount the lefthand side roll-over protection unit to access the FCTM and to check the status of the connections.
It could very well be that a previous owner has disabled the quarter window power motors,stuck in closed position, to avoid they would stick open with the malfunctioning roof.
Funny thing: when having "Roof not latched" when fully closed, I manage to remove the message by operating the tonneau closure cilinder towards the "pivot over center" position firmly. Lo and behold: "Roof not latched" message disappeared!
Nonetheless, the roof does not respond to opening or closing.
I will post my findings as I go.
Old Sep 18, 2022 | 05:04 PM
Stuart S's Avatar
Make sure that your battery is fully charged and that the engine is running when you operate the top.
Old Sep 19, 2022 | 11:51 AM
sbolinha's Avatar
Thanks for the tip. Of course: I use a 40 Amps battery power supply for this purpose, well capable of raising the convertible roof.
I believe my issue is due to water ingress after a dislodged rear window.
I will need to pull the over roll restraint and check the rear quarter window power supply, which also carries the earth return of the Tension bow valves 2 an 3.
Either the plug is corroded after water ingress or de module itself is soaked.
I believe this as a viable answer to the combined issues I reported above.
Old Sep 24, 2022 | 07:30 AM
sbolinha's Avatar
Follow=up: today, I removed the over roll restraint airbag to access the convertible top module.
My deduction was correct: there is something wrong with the plug driving the rear quarter windows and the earth of the tension bow valve solenoids.
The problem was not water ingress... everything was dry. The problem was simply that the plug was not plugged in the computer.... ;=)
I plugged it in, mounted everything back and tested the roof, essentially it works both in opening and closing direction.
What does not work:
1. it does not finish full closing. When I close further using an allen key, also the rear windows go up electrically.
2. it does not finish full opening: the tonneau cover does not latch.
So essentially, I have reduced the open top issue to adjustment of the tensioner cables and closing of the tonneau.
Old Mar 24, 2025 | 07:51 PM
Jagxk07's Avatar
Do you still have this module and if yes is the one controlling the rear windows as well? How much would you sell it?
Thank yoy
Old Mar 24, 2025 | 10:02 PM
Cee Jay's Avatar
Thank yoy
Slash hasn't been active for two years, though he may get an alert from your quote.
Jdwoody17
Apr 22, 2022 09:55 AM
brinny
Apr 5, 2020 09:47 AM
Jagman46
Nov 6, 2017 08:28 AM
Anthony8858
Jun 2, 2017 06:55 AM
unders
May 28, 2014 09:48 AM
