current gear display
One minor annoyance on my 2008 is that the gear display won't tell you what gear you're in - unless you change up or down. A couple of times I've done a couple of quick taps on the down shift and ended up in 1st where, if I'd known it was in 3rd I might have only flicked it once
I'm sure I've seen a pic of a 2010 dash with a big number in the display between the spedo and rev counter.
That just ain't right...
Mine will highlight the gear you are in when tapping them. I think it will downshift if it sees that it can but mine still will show the gear it goes into if it shifts down it's self. I did read that there was a change in the actions of the paddles starting in 08 on the XF. I don't know if that carried over to the XK or not.
The big numbers in the display show up when in S mode with the performance button on. Otherwise, when you do a gearshift, it has a smaller number it shows near the top of the LCD until it goes back into 'auto' mode.
hen555
Sep 7, 2015 11:13 PM
