Daylight Running Lights Wiring
Old Oct 9, 2015 | 12:15 AM
tommyzr's Avatar
Question Daylight Running Lights Wiring
Can anyone tell me where an ignition wire is & what color under the bonnet of my 2010 Jaguar XK ...please. I want to tap into it so I can add LED daylight running lights. If I did tap into it, would this interfer with any amperage load on the electrical system & drive it bonkers?
Old Oct 9, 2015 | 02:35 AM
Tommy,
I've moved your question from USA Mid West Region to X150 forum.
This is the place to post tech questions about your XK. Members here with the same model will be able to help.
Old Oct 9, 2015 | 06:15 AM
old_dawg's Avatar
Take a look at this thread, where I went through wiring my lights..
https://www.jaguarforums.com/forum/x...lights-119368/
Old Oct 10, 2015 | 12:10 PM
wrair's Avatar
Tommyzr,
I'd like to add DRLs, too, same year. Where did you get your DRLs, where are you putting them, and what color? I like the yellow/orange I see on some cars.
Old Oct 10, 2015 | 01:35 PM
Cee Jay's Avatar
LEDs take about a billionth of an amp, so that would be zero problem. The REAL problem is that you'd look like an Audi wanna-be.
Me personally, I can't stand Audis but only because I drove them. Horrid little junk bucket rattle-traps.
Old Oct 10, 2015 | 03:13 PM
wrair's Avatar
Not if they are round DRLs. Round goes with the cats curves.
Old Oct 10, 2015 | 03:18 PM
u102768's Avatar
Perhaps you haven't driven the right ones. I bought my wife a 6 year old S4 a few months ago and it is a brilliant car. Pulls like a train from standstill and comes loaded with toys some of which have only just made it in to the Jaguar range e.g. tourque vectoring.
The air-con settings are matched to the key fobs so I can have it set to what I like and my wife can have furnace mode. It also has individual settings for power steering, sports mode, diff control and suspension so when I get in the car I flip it to custom mode and it uses my pre saved preferences to set the car how I like it.
Old Oct 10, 2015 | 03:42 PM
franksm's Avatar
I am in the same boat - fitted OSRAM LEDriving DRLs to my XK just today but am stumped with finding a permanent + and IGN + under the bonnet. When I did the same job on my 1997 XK8, it was a mite easier.
I have the wiring diagrams, and the "Connector Quick Reference" docs but it looks like there are no easily available points for connection under the bonnet - unless I go to the fuse box, but the loom is so tight there, it'll pretty much need to be dismantled. I don't want to disturb those connectors if at all possible...
Old Oct 10, 2015 | 04:06 PM
Cee Jay's Avatar
If you need to know which wire will meet your needs, just ask Steve (aka white xkr). he knows almost everything.
Old Oct 24, 2015 | 12:59 PM
tommyzr's Avatar
I answered my own question about adding DRL's to my '10 XK coupe. I emailed a Canadian Jag dealer because DRL's are required there.. After receiving my vin number, they said my '10 XK's computer can be reprogrammed to allow the DRL's to operate, but a dealer with the correct code/program would be needed to do this. So it's not a DIY process. Then I went back to my local dealer, after they 1st saying it's not possible, and ... yes they can do the job. The computer has to be "tricked" into "believing" it's a Jag produced for Canada. Takes about an hour to do. So, I don't know what other model years that the computer can be programmed to allow the DRL's to operate, but at least the '10 Jag XK can. Good luck.!!!
Old Oct 24, 2015 | 01:04 PM
tommyzr's Avatar
Default Wrong XK
Originally Posted by GGG
Tommy,
My car is a 2010 XK .... not an X150. See thread #10 as I answered my own question.
Old Oct 24, 2015 | 01:06 PM
tommyzr's Avatar
See post #10 ...answered my own question.
Old Oct 24, 2015 | 02:02 PM
Stuart S's Avatar
tommyzr,
"X150" is the Jaguar factory production designation for all alloy-bodied XK/XKR coupe and convertible model years from 2007 - 2015 (North America; other markets began in 2006). Your 2010 XK is an X150.
Stuart
Old Oct 25, 2015 | 04:06 PM
tommyzr's Avatar
Default DRL's X150
Thanks Stuart S. Didn't know X150 was the designation for the 2007 - 2015
all aluminum body XK.
Tommyz
Old Oct 25, 2015 | 05:37 PM
tampamark's Avatar
My 2012 has the front corner LED's as a DRL, is this standard in my year XK? I don't know of the previous owner had it wired, programmed, both or none!
Old Oct 26, 2015 | 07:41 PM
ralphwg's Avatar
in 2012 the front corner LEDs are your DRLs.
HypnoGuru
Oct 23, 2018 09:53 AM
leep123
Sep 26, 2015 04:53 PM
Pilotman11
Sep 18, 2015 11:35 PM
Corycarlo
Sep 13, 2015 06:46 PM
thefixer
Sep 11, 2015 09:17 PM
