Display flicking on start up then going black on 2007 XK
Old Nov 1, 2021 | 12:02 PM
Serv75's Avatar
Default Display flicking on start up then going black on 2007 XK
I do not know what the problem is with my jaguar. I have checked all 3 fuse boxes. I checked the navigation, cd player, and dvd player optics and they are all fine. Does that mean the display is bad only? Radio works but I just cant see on the display, because it is black. Could it be a bad connection to the display? I dont know how to get to it to check. Any suggestions?
Old Nov 1, 2021 | 05:05 PM
sov211's Avatar
Battery. Battery, battery....
Old Nov 1, 2021 | 08:51 PM
Serv75's Avatar
Should I take battery off then recharge and then try again?
Old Nov 1, 2021 | 10:22 PM
guy's Avatar
guy
either connected or not. choice is yours. If its nearing 5 years old, I just replace mine at the signs of trouble.
Old Nov 2, 2021 | 08:50 AM
jahummer's Avatar
It's either the main battery failing, a bad ground or the TSD itself is going...all 3 options are common causes, main battery issues will cause all sorts of glitches, bad grounds will as well but as these age, there are some now which are failing. Have the battery load tested at a local auto parts or battery supplier for free which will at least eliminate that. Also try a reset by disconnecting the battery cables and touching the leads together briefly. If it's a ground, could take a bit more time an if you're not comfortable working on cars have a specialist take a look.
Old Nov 2, 2021 | 12:25 PM
Sean W's Avatar
A faulty Bluetooth module will also cause strange behavior on the touchscreen but if it were my car, I'd check out the battery first, then the ground points as jahummer suggests. Just pick up a fiber optic bypass loop on Amazon and loop the BT module out of the circuit.
Old Nov 2, 2021 | 03:02 PM
007XKR's Avatar
Once I started keeping my cat on a CTEK, these screen issues went away. Mine would start up, then go black, and repeat a few times before eventually staying on. So far, I can't find any loose or corroded grounds, so I attribute my screen issues to battery voltage.
Old Nov 15, 2021 | 07:22 PM
Serv75's Avatar
The battery checked out good and no problems at resting or after starting. I have by passed the cd player, navigation, Bluetooth and still flicking logo and then goes black. The fuse 14 in the back seat was good that supplies to display and navigation. How do I check the ground to the display? Well, I mean do I have to take the console off or just look on the back of the display? Someone told me its on pin 6, but I dont know where that is. I was thinking it might be under the console, but I dont know how to take off on a 2007 jag xk. It probably is simple if someone can guide me. Anyone know the answer?
Old Nov 15, 2021 | 07:24 PM
Serv75's Avatar
What does TSD mean? I am new to the abbreviations on cars.
Old Nov 15, 2021 | 07:26 PM
Serv75's Avatar
What does cat on a CTEK mean exactly? I am new to car abbreviation terms. Where exactly is it on my 2007 jaguar xk, also?
Old Nov 15, 2021 | 07:33 PM
Sean W's Avatar
TSD= Touch screen display
cat - Jaguar as in Kitty cat
CTEK = battery maintainer
Rabs
Sep 10, 2021 05:25 PM
John202
Nov 19, 2020 07:32 AM
Andreas Schmieg
Nov 12, 2017 07:29 AM
newtcopa
Jun 15, 2012 03:53 AM
Riski
Jan 26, 2010 02:16 PM
