Does this doohickey connect to this thingamajigg?
Old Nov 9, 2019 | 03:03 PM
SpinningWheels's Avatar
Default Does this doohickey connect to this thingamajigg?
Coming from the rear passenger wheel well is this small tube. When I got under the vehicle to see where it originated, I saw this fitting that appears to be missing a connection. Does part A connect to flange B?
Old Nov 9, 2019 | 03:08 PM
Don-T's Avatar
Uh, what kinda car you got?
Old Nov 9, 2019 | 04:12 PM
DannyJ's Avatar
Looks like the tube is the drain from the fuel cap
Old Nov 9, 2019 | 05:40 PM
Stuart S's Avatar
It's in his Public Profile.
Old Nov 9, 2019 | 05:56 PM
+1
RH rear wheelarch liner removed - looking towards the rear of the vehicle.
Old Nov 9, 2019 | 05:59 PM
So are the vehicle details ......NOW. I've just added them.
Old Nov 10, 2019 | 06:46 AM
You gentlemen are correct. Another scooch under the car and I see where it originates and also where it should terminate. Thanks for the help and a special thanks for the visual assist, Graham. I don’t care what anyone says about this group, you’re aces to me.
Old Nov 10, 2019 | 06:48 PM
Sean W's Avatar
For future reference Spinning wheels, "whatchamacallit", "whosit", "thingy" and "canudinator" (valve obviously), are acceptable industry terms.
Please note, the more accurate you are in using correct terminology, the better we're able to assist you.
Thingamabob and Doodad are also acceptable Jaguar terms but only if you have the proper code reader. They will not work with generic code readers.
Old Nov 11, 2019 | 04:54 AM
barnsie's Avatar
Indeed. Not to mention that one of the most important things wrt to Jaguar maintenance is the correct interpretation of the blinkenlights.
https://en.wikipedia.org/wiki/Blinkenlights
sunchip
Aug 28, 2023 09:21 PM
2jags1993
Sep 19, 2019 01:58 AM
Brewtech
XJ40 ( XJ81 )
Aug 11, 2019 10:55 AM
julien4020
Aug 19, 2017 01:34 AM
IronCobra
Dec 25, 2006 12:54 AM
