DRL 2010 bumper!
Old Oct 25, 2019 | 12:44 PM
peterv8's Avatar
Default DRL 2010 bumper!
Been fiddling a bit with my new bumper and mounted some leds, they are very bright. I had to drill the grills so they could fit but if I ever take'm off I don't think you notice the slightly larger holes in the grill. Could only fit 4 leds because of the shape of the grill, I would have to make a larger hole for the 5th but I didn't want to do that. Bought the leds from Ali. Will connect them to the front foglights so don't need to rewire! ��
https://s.click.aliexpress.com/e/MYcvadNI]http://SEK 14.03 20%OFF | 2PCS 12V Eagle Eye LED Light 12SMD 23MM Car DRL Daytime Running Waterpproof Light Motorcycle Screw Lamp Backup Signal Light Bulb https://s.click.aliexpress.com/e/MYcvadNI[/url]
Now only need to test mount the bumper before paint! ��
Old Oct 25, 2019 | 02:31 PM
u102768's Avatar
The link doesn't work on my laptop but after a bit of fiddling this seems to be what it was trying to link to:
https://www.aliexpress.com/item/32975776726.html
Old Oct 25, 2019 | 02:41 PM
peterv8's Avatar
Don't know why mine doesn't work but thanks, those are the one's! 😊
Old Oct 25, 2019 | 04:20 PM
Cee Jay's Avatar
Originally Posted by peterv8
........................... Will connect them to the front foglights so don't need to rewire! 😊
Where are those? I've never seen 'em.
Old Oct 25, 2019 | 04:25 PM
peterv8's Avatar
Here you go! 😊
Old Oct 25, 2019 | 08:47 PM
Cee Jay's Avatar
Yeah, since dude has a '10-11, your '08 don't count.
Old Mar 30, 2020 | 11:26 AM
peterv8's Avatar
Finally it's time to fire up the Jag! New bumper is fitted with my DRL's!:-)
DRL on
DRL off
They shine nice and bright even though it doesn't show in the pic but my headlights are also on and they are not bright either in the pic.
Old Mar 30, 2020 | 12:05 PM
Cee Jay's Avatar
Cool, man.
Many years ago I did the CCFL ring thing around my front Growler. It's still there, still works, but I have it hooked to the running lights.
Old Mar 30, 2020 | 12:44 PM
peterv8's Avatar
Deleted, double post!
Old Mar 30, 2020 | 12:46 PM
peterv8's Avatar
Cool with the led growler. :-)
I'll get some pics later this week when it's darker out.
Old Mar 31, 2020 | 10:02 AM
tberg's Avatar
PeterV8,
This is something I've wanted to do to my 2010 XKR for a long time. As I've gotten older, my peripheral vision has become terrible and whereas on my 2002 X100 XKR there are fog lamps which light up the sides at night for me, the 2010 does not have fog lamps, so it requires running new wiring to the grills. You've inspired me to try and get it done while I can still see anything.
Thanks.
Old Apr 4, 2020 | 05:00 PM
tbaxl's Avatar
While I am changing my bumper cover, and waiting for parts, I think I am going to copy you. Did you source a connector for the lamp end or just cut and splice wires.
Thank you for the idea.
Tim
Old Apr 5, 2020 | 12:32 AM
peterv8's Avatar
Tim
I cut the connector off and used 4 of these..:-)
Each led has a positive and a negative cable so 8 cables of each side.
The Leds I bought from Aliexpress and will probably break more frequently so with that connector I can pretty easy change a led when one breaks!:-)
Old Apr 5, 2020 | 09:56 AM
tbaxl's Avatar
Great idea with the connector but I have to question corrosion issues. Is it waterproof, or how did you address moisture issues?
More parts are on order.
Tim
Old Apr 5, 2020 | 01:16 PM
peterv8's Avatar
Tim
Mine is always garaged and avoid rainy days. The little I drive in the rain will be no problem as they are protected against direct water behind the bumper.
Time will tell! :-)
xjrjag
Feb 19, 2019 08:53 AM
Fezz
Mar 1, 2014 11:58 AM
RickG
Oct 15, 2012 11:39 AM
wolv2401
Feb 21, 2010 11:09 PM
bombu
Nov 14, 2009 10:04 PM
