Failing Emissions Test
Old Jul 30, 2025 | 05:10 PM
johnsonike's Avatar
Default Failing Emissions Test
Hello,
I have a 2012 Jaguar XKR that has been sitting for a year. I decided to get it registered here in Atlanta. So, I used a jump box to start it and took it to a local shop for an emissions test. It failed (READINESS). I put in a new battery. Still failed. On advice of the shop operator I drove it for 40 miles hoping to reset the computer. No luck. Any suggestions?
Thanks in advance.
Ike
Old Jul 30, 2025 | 05:34 PM
Cee Jay's Avatar
3/4 tank of fuel, nice easy long trip of at least 100 miles with little stopping.
The EVAP is the last and longest self-test. Some locales are okay with one Not Ready light, like where I live. It saves aggravation. And fuel.
Old Jul 30, 2025 | 05:39 PM
kj07xk's Avatar
Some have needed around 200 miles to get ‘ready’:
Readiness
Old Jul 30, 2025 | 08:45 PM
johnsonike's Avatar
Thank you. I will try it.
Old Jul 30, 2025 | 08:46 PM
johnsonike's Avatar
Thank you. I will plan for a long drive tomorrow.
Old Jul 31, 2025 | 11:15 AM
Stuart S's Avatar
@johnsonike Because your XKR has been sitting for about a year, I suggest that you put a can of BG44K fuel additive in your gas tank before your next fill-up. That way is best, in order to mix it thoroughly with the gasoline. BG44K effectively cleans fuel injectors.
Old Jul 31, 2025 | 07:54 PM
guy's Avatar
guy
And before the long drive, perform a reset.
Old Aug 1, 2025 | 12:24 PM
johnsonike's Avatar
Thanks! It passed!
Old Aug 1, 2025 | 04:00 PM
McJag222's Avatar
Old Aug 1, 2025 | 05:40 PM
Stuart S's Avatar
Originally Posted by McJag222
See Post #6 for how to do a Hard Reset:
https://www.jaguarforums.com/forum/x...-reset-291002/
Old Aug 2, 2025 | 01:40 AM
JagV8's Avatar
If it was sitting with flat battery, that is already a reset.
Old Aug 2, 2025 | 11:39 AM
KurtC's Avatar
From “Technical Training 688-JAG: Advanced Electrical Systems and Diagnostics”, page 3-15, covering Control Module Programming:
“When resetting the battery (hard reset), disconnect both battery leads and touch them together to fully discharge all control module capacitors.
NOTE: A hard reset does not repair a fault condition. It simply brings all control modules back to their baseline condition. If a hard reset eliminates the symptoms, then further diagnosis is needed to determine the cause of the conditions, i.e. low battery causing a single control module to come off line temporarily.”
Johntechwriter
Sep 19, 2019 07:24 AM
BongoBilly
Jul 4, 2019 10:11 PM
Wende Frost
Jun 13, 2018 11:11 PM
oldjaglover
Apr 18, 2018 07:11 PM
etaent
Apr 24, 2012 06:05 PM
