Fault Codes
Old Jun 5, 2019 | 05:32 PM
pauledddy's Avatar
Default Fault Codes
Evening folks
Got 2 weird fault codes appear on my XKR
P0610 and P0630
Car isn't affected, drives fine, starts fine, changes gear fine.
Tried clearing the codes, but they reappeared. I did have the battery off while fitting something, and it was after I are attached the connectors these codes appeared.
Any help would be much appreciated
Old Jun 5, 2019 | 08:07 PM
jagtoes's Avatar
Originally Posted by pauledddy
Evening folks
P0610 and P0630
The first question is what were you doing or fixing that you needed to remove the battery cables. Were you doing any electrical work or programming anything. I would be concerned with the P0630 as this one does not recognize the vin number of your car and could potentially prevent your car from starting.
Old Jun 6, 2019 | 01:26 AM
pauledddy's Avatar
I was adding some exhaust valves so took the battery off to fit the cables. The car starts fine, literally no issues at all
Old Jun 7, 2019 | 05:17 AM
pauledddy's Avatar
Anyone have any input on these codes?
I've bought an SDD, I know about the constant battery voltage needed as well. So will update further when I have my car back from the paint shop
Old Jun 7, 2019 | 05:33 AM
Cambo's Avatar
Someone did, or tried to, re-map the car in the past? Flash a different engine tune to the car?
In any case you will be rolling the dice trying to re-flash the PCM, CJB or RJB with an eBay or British Diagnostics crap SDD.
Personally, if the car starts, runs and drives fine, no errors on the dash, then I'd let sleeping dogs lie...
Old Jun 7, 2019 | 08:43 AM
Originally Posted by Cambo
....... if the car starts, runs and drives fine, no errors on the dash, then I'd let sleeping dogs lie...
+1
If I don't have a MIL, an error message or a bad feeling about how the car is running, I leave my SDD alone.
Old Jun 8, 2019 | 10:04 AM
pauledddy's Avatar
I don't know if it's been mapped in the passed. The EML is illuminated and won't clear. But as stated it drives fine, but the light is bothering me!
How do i go about this issue??
Old Jun 8, 2019 | 11:43 AM
kj07xk's Avatar
Possible to contact the previous owner, to see if a mapping was done?
Old Jun 8, 2019 | 11:48 AM
pauledddy's Avatar
So, I've just disconnected the battery for a good 10-20 minutes and the code has disappeared.. haven't driven it yet si not sure if itll come back!
Old Jan 14, 2025 | 06:33 PM
Hajima's Avatar
I disconnected my battery to change out headlights, and even started the car after reconnecting the battery. No issues then, but the next morning... 🙄
Also been driving with no issues. My diagnostic tool did list a history of cleared faults and gave me the impression that the ecm had been replaced. Something about mismatched VIN #s. I guess it's dealership time.
jaguar0206
Dec 8, 2019 07:43 PM
SynySTR
Oct 17, 2014 09:33 AM
bassman64
Apr 20, 2014 04:25 PM
XTypeJagMan
Feb 28, 2014 08:38 AM
