FIX for Blower Control Module (BCM) Confirmed
Old Aug 13, 2015 | 06:39 PM
Dan's Avatar
Dan
Default FIX for Blower Control Module (BCM) Confirmed
I am starting a new thread confirming that the Airtex 4P1652 is an exact replacement for the OEM BCM for a 2008 XKR. The part can be found on Rock Auto's website for under $70. Search for part number 4P1652.
The replacement is ridiculously easy as well! There are several threads on here that document the repair. See my original thread for more details: https://www.jaguarforums.com/forum/x...08-xkr-147151/
Thanks to this awesome forum for saving me from paying the Jaguar dealer $1,700 for this easy repair!
Old Aug 14, 2015 | 06:12 AM
Booskisjag's Avatar
Where is the bcm located? I think mines wet out about 2 days ago
Old Aug 15, 2015 | 09:30 AM
Dan's Avatar
Dan
the module is located in the passenger footwell area to the left of the blower motor itself. If you remove the cover over this area, you will see the blower motor in the center. To the left is a grey plastic part with a plug. Simply remove the two screws and unplug it and replace. There is a thread or two on here walking through the troubleshooting of the part itself.
What are your symptoms?
Here is a picture of the BCM next to the (removed) fan motor.
Here is the original BCM. Mine failed due to the TCO which is a $1.85 part at Fry's.
Jaguar 2008 XKR BCM
Here is the replacement part from Airtex available at Rockauto
2008 Jaguar XKR BCM
New Jaguar 2008 XKR BCM
Old Aug 16, 2015 | 02:10 PM
Booskisjag's Avatar
I went to turn my A/C on but I can feel the cold air but it's not blowing... I thought it might be the motor and then I seen your post Dan. What do u think
Old Aug 16, 2015 | 03:56 PM
RedRider48's Avatar
Interesting occurence, happen to be reviewing all of the service history of my '08 XK-R, and don't you know, the blower motor was replaced in Jan 2013 with 34.7K miles.
Old Aug 19, 2015 | 09:02 AM
Dan's Avatar
Dan
The BCM is the easiest and lowest cost to replace and is a good starting point. You can also remove the fan quite easily and see if it spins freely. There are three screws holding in the fan, remove those, drop the fan and spin it.
There are some other threads on here discussing how to jumper the fan to see if it works so you can determine if it's the BCM.
-Dan
Old Aug 19, 2015 | 09:05 AM
Dan's Avatar
Dan
It's sad that dealers just want to replace all parts regardless. Of course this repair is really easy and is high profit. They need to make money but this repair and cost is bordering on absurd.
Old Aug 19, 2015 | 04:02 PM
MoscowLeaper's Avatar
Most of the dealers would love to repair a things instead of replacing it, but the car manufacturer strogly prohibits to do so...
Old Aug 20, 2015 | 10:32 PM
Dan's Avatar
Dan
I agree repairing the BCM would not be wise but they do not need to tell me that three parts are bad when in fact only one is. They can get away with quoting high prices because most people don't bother to question the quotes.
Old Aug 21, 2015 | 04:40 AM
Well, i was a technical trainer in JLR Russia. Belive me, it's hard to fine a good techs, who can diagnose a car properly, instead of replacing everyting in case "Let's see if it helps" But it's easy to find a sales manager, a lot of them. O tempora o mores.
Old Sep 14, 2015 | 08:43 PM
SunBu's Avatar
Dan I just wanted to thank you for the thread on the Blower Control Module. My AC stopped working about a month ago. I read your threads and followed all of your suggestions. Today I received the new BCM from RockAuto. It took me 15 minutes to replace it. Thank you again I am back in business in my sexy ride!!!
Old Sep 18, 2015 | 11:02 PM
Booskisjag's Avatar
Hey guys so I changed the blower motor today but still nothing blowing, is there a way I can test the bcm to see if it's bad? The motor was bad cause the old one wouldn't spin at all...
Old Sep 23, 2015 | 04:11 PM
Booskisjag's Avatar
Change the BCM today after changing the Motor last week and there was my 2 problems, thanx for all the help guys!!!! Here is a pic of the BCM that was bad but I don't kno which piece is no good
H20boy
Dec 24, 2024 03:23 PM
Steviedee1st
Nov 28, 2023 06:32 PM
XJsc-guy
Sep 25, 2015 11:09 AM
Saturbo
Sep 8, 2015 07:35 PM
jaguarbill
Sep 5, 2015 11:43 AM
