Front subframe
Old Aug 28, 2022 | 04:45 PM
Glasgowjim's Avatar
Default Front subframe
Hi folks,
Does anyone know if the front subframe is the same on Both coupe & rag top ?
2010 Xkr
thanks
Old Aug 28, 2022 | 05:11 PM
steve_k_xk's Avatar
Yes , yes and yes and even a aluminium f type subframe from a rwd with non electric rack will bolt up
Old Aug 28, 2022 | 05:36 PM
Glasgowjim's Avatar
thanks Steve,
So the f type frame fits and it’s aluminium
great info. I’ll look into that
rwd with hydraulic rack
so an earlier f type
makes sense I fitted an f type aux rad and it sits inside.
I owe you a beer 👍
Old Aug 28, 2022 | 11:17 PM
steve_k_xk's Avatar
Old Aug 29, 2022 | 05:59 AM
Originally Posted by Glasgowjim
..... Does anyone know if the front subframe is the same on Both coupe & rag top 2010 Xkr .....
There is no difference in the crossbeam used for the Coupe and Convertible. The part has been superseded three times:
The last version is listed as fitting the entire X150 range from 2007 - 2014.
Old Aug 31, 2022 | 02:44 PM
panthera999's Avatar
Sorta related question. Need to replace swaybar D-bushings. Is it possible to just lower the subframe a couple of inches to do the job by backing out the bolts and a-frame, without a bunch of hassle beyond disconnecting the steering knuckle? And maybe the four shockmount nuts? Looks like the assembly would rotate down to the limit of the upper suspension mount (#4 and 14).
Would do it on a lift with screw-jacks supporting the subframe, with a top brace supporting the engine, of course.
Note (according to the 5.0 manual) the 5.0 D-bushings are relatively easy to replace. The 4.2 manual wants me to remove the subframe, which seems major overkill. This is a 4.2.
Old Aug 31, 2022 | 04:07 PM
steve_k_xk's Avatar
Panth yep that's the way I did mine prior to a full subframe removal
Old Apr 2, 2024 | 07:28 AM
Jay f's Avatar
Default Xkr - f type front subframe
hi Steve
I noticed in the above thread that you mentioned that the ftype subframe fits the xk. Is it a straight swap or is there suspension components that need changing too?
Mine has rotted out near the banana link so need to replace and ftype ones are little less rare and alloy would be a bonus too!!
thanks in advance
jay
2010 xkr 66000 miles
Old Apr 2, 2024 | 05:06 PM
steve_k_xk's Avatar
There is a few variances of the subframe, you want the spec'd subframe with RWD & the hydraulic rack (there's also AWD & electric rack which isn't what we want )
bullittandy
Nov 2, 2024 03:44 PM
Marley
E type ( XK-E )
Jun 24, 2021 08:17 PM
Rudy Mensink
Nov 2, 2019 03:06 AM
