Gas cap removal problem
Old Oct 25, 2020 | 10:26 AM
donricardo440's Avatar
Default Gas cap removal problem
I have a 2012 XKR convertible that I just acquired from my son. 58,000 plus miles. The first time I went to get gas in the car I released the gas cover from the button inside the car. The door popped open no problem. When I went to turn the gas cap to remove it there was a problem. I just couldn't get the thing to pop out of the gas filler. I turned it clockwise until it clicked and then reverse counterclockwise all the way. It took five tries to get it out. I've been dealing with gas caps for 60 years and I've never had this happen. Any ideas out there? I appreciate any response.
Old Oct 25, 2020 | 10:52 AM
Cee Jay's Avatar
Buy a new gas cap? Seems like the one on it has worn.
Old Oct 25, 2020 | 01:14 PM
Stuart S's Avatar
I expected finding this gas cap to be easy, but ...
Other than the price, what's the difference between these two gas caps?
Old Oct 25, 2020 | 03:55 PM
JEPC lists two types of Fuel Filler Cap:
1. 1/4 turn (VIN range dependent)
2. Other option
I can't imagine what "Other Option" could be.
Old Oct 25, 2020 | 05:01 PM
Cee Jay's Avatar
Other Option could be the non-quarter turn one, that keeps on ratcheting when it gets tight.
Old Oct 25, 2020 | 08:35 PM
Stuart S's Avatar
Old Oct 26, 2020 | 03:51 AM
I'd assumed quarter turn referred to removal and not replacement.
It never pays to assume with Jaguar. All the ones I've had in recent years have ratcheted. I didn't know US was different.
Old Oct 26, 2020 | 04:35 AM
guy's Avatar
guy
Actually...
File Type: pdf
Old Oct 26, 2020 | 09:04 AM
The gas cap does not have a key to remove. It is like every other gas cap I've seen on cars here in the United States. Clockwise until it clicks. Counterclockwise it's supposed to just flip right out. Not happening with this car.
Old Oct 26, 2020 | 10:40 AM
Cee Jay's Avatar
Maybe because it's broken? Get a new cap. New caps work.
The cap on my XKR rotates clockwise 90 degrees then ratchets. Removal, it free-spins a half-rotation (180 degrees) and then engages; a quarter-turn more and it's out.
Old Oct 26, 2020 | 02:01 PM
Thanks for the information. At least now I have something to go on. If I still have a problem then you're probably right I will need a new gas cap.
Old Oct 26, 2020 | 06:38 PM
I followed the advice of Cee Jay. Problem solved! Thanks so much for the information. That quarter turn was something I ever had no experience with. I've been driving Ford explorers for about 10 years and they don't have gas caps. Just open up the door on the gas filler, put the nozzle in get your gas. Take the nozzle out and close the door and you're done. A simple answer I know for the gas cap. But it sure helped me a lot. Thanks again.
salukutinaveen
Oct 22, 2017 10:16 PM
Sep 2, 2016 10:26 AM
Stogie
May 30, 2013 02:01 PM
pan84
Nov 19, 2011 08:41 PM
vaccaro81
Mar 8, 2007 02:32 PM
