Hard reset
Old Mar 11, 2022 | 02:49 PM
Tony Vasquez's Avatar
Default Hard reset
Has anyone tried the “Hard Reset” procedure? IE, disconnecting both terminals then placing Negative cable on positive terminal? Sounds very risky to me??
Old Mar 11, 2022 | 03:01 PM
Cee Jay's Avatar
Probably everyone in here has done this at least once. It's a Jaguar Suggested Procedure.
Old Mar 11, 2022 | 03:16 PM
Sean W's Avatar
Yep as Cee Jay says, it's a common practice and recommended by Jaguar under certain conditions. No need to worry as this is what it does. A ‘hard reset’ restores the control modules to their base conditions assuring that network communications are synchronized.
When resetting the battery (hard reset), disconnect both battery leads and touch them together to fully discharge all control module capacitors.
NOTE: A hard reset does not repair a fault condition. It simply brings all control modules back to their baseline condition. If a hard reset eliminates the symptoms, then further diagnosis is needed to determine the cause of the conditions, i.e. low battery causing a single control mod- ule to come off line temporarily.
Old Mar 11, 2022 | 03:21 PM
Sean W's Avatar
You have this very wrong! You can do a hard reset one of three ways.
1) Using Jaguar approved software
2) X150 Vehicles
  • Due to the window drop entry feature, the following procedure should be followed to prevent door seal damage.
  • Open one window fully or open a door
  • Disconnect the negative cable of the battery for at least 120 seconds
  • Reconnect the battery negative cable
Reset the window position memory for the passenger and driver door windows
3) Same as 2 above except remove both Negative and Positive cables from the battery and touch the cables together. Do NOT touch your negative cable to the positive post of your battery.
Old Mar 11, 2022 | 03:56 PM
jahummer's Avatar
Also for clarification, this is a "soft" reset, good for anomalies and glitches, it doesn't provide module specific "hard" resets exclusive to JLR's proprietary SDD diagnostics software.
Old Mar 12, 2022 | 03:25 AM
Has anyone tried the “Hard Reset” procedure? .....
YES - as stated above, most of us will have done this at some time.
However, WHY do you want to do this and WHAT do you hope to achieve? It will eliminate all 'learned' settings and reset them to default by discharging the capacitors BUT it will not magically clear troublesome error codes.
Old Mar 14, 2022 | 12:29 PM
JagV8's Avatar
Also clears the things needed by many regions for "smog" testing i.e. will fail smog until the various things (*) re-set (as in: set again).
(*) OBD monitors
Old Mar 14, 2022 | 12:33 PM
Cee Jay's Avatar
(*) OBD monitors
Yep, and the EVAP part may take up to 200 miles to reset. Lucky for me, Utah allows one "Not Ready" to pass inspection.
Old Mar 18, 2022 | 02:48 PM
The reset question was mostly out of curiosity. My current issue is still with the convertible roof. I'm able to clear the "front latch" error msg however, when closing the roof automatically, it reaches the front latches then starts to click continuously as if the cable is jammed somewhere and slipping < this is my best guess> . Does anyone have experience with this sort of situation?
Old Mar 18, 2022 | 04:41 PM
Sean W's Avatar
think you'd get a better response if you started a new thread with a better title as this one doesn't apply.
Old Mar 19, 2022 | 01:13 PM
MarkyUK's Avatar
Oops posted in the wrong place
Old Jun 7, 2024 | 12:36 PM
justinhill's Avatar
(*) OBD monitors
I still have bad memories about this. My X308 4.0 had a bad lambda sensor. I replaced it - having disconnected the battery - and then presented it for MOT, which it failed on emissions of course. But I'd got myself into that position where the tax disc ran out at the same time as the MOT so I couldn't renew the tax. So I had to drive it untaxed to get the engine management to re-learn. I went to a studio to do a day's work. While I was there the car was clamped for having no tax. I had to hang around for several hours and then pay several hundred quid to get it unclamped and the fine paid so I could drive it home again. It passed emissions the next day though. I learned to never have tax and MOT expire at the same time...
Old Jun 7, 2024 | 12:43 PM
Cee Jay's Avatar
Beats me about UK, but here a 14-day temporary tag can be had for like six bucks.
Old Jun 9, 2024 | 06:32 AM
Lothar52's Avatar
I’m never leaving Columbus Ohio… we never need to do MOTS… E V E R…
Old Jun 9, 2024 | 09:40 AM
guy's Avatar
guy
Perhaps the reason why there are so many unworthy and unsafe cars on the road??
Old Jun 11, 2024 | 04:33 PM
JagV8's Avatar
We don't have anything remotely like that here, sadly. Just tough laws and harsh fines.
flyfish
Oct 24, 2022 01:58 PM
magnum454
Apr 1, 2018 05:37 PM
Steve-in-ct
May 15, 2017 12:33 PM
mick99
Sep 7, 2016 09:38 AM
pdog2000
Feb 1, 2012 10:39 AM
