Help! Battery dead, can't open the trunk!
Old Mar 28, 2018 | 02:31 PM
mosesbotbol's Avatar
Is there a pull cord in the back seat? Lotus and Aston do that one
Old Mar 28, 2018 | 03:13 PM
Jimscriv's Avatar
Sorry About that, followed a link from a web search and didn't enter the forum properly. The under the hood method did work, I left the boost pack on it for an hour or so and was actually able to start the car. Thanks for the info though!
Old Mar 29, 2018 | 04:48 PM
Cee Jay's Avatar
Sort of like this???
I don't know if the video link will work, can't find video-only....
https://www.facebook.com/carthrottle/videos/2074418882569151/
Old Apr 25, 2020 | 06:26 PM
David Wilhelm's Avatar
I had the same thing happen to me. Have a 2005 XKR. If I don't drive the car often, the electronics within 2-3 weeks drain the battery. I couldn't open the trunk with the key through the R so I looked for the positive lead on the driver's side under a rubber cap. Bam! There is was. Hooked up the positive and negative to the frame and I hope it works. It should. Thank you.
Old Nov 15, 2023 | 07:42 AM
CedricQ's Avatar
Originally Posted by Swagga
Under the driver's side rear fender, about 1ft behind the rear tire-well, there is a positive terminal covered with a rubber cap. I found it without jacking up the car, hooked on a battery charger, negative cable clamped on the frame, charged for about a minute and that was enough juice to pop the trunk! Simple and easy to find once you know where to look.
Even 10 years later, this thread helped me opening my trunk.
thanks a lot !
Cedric
dsnyder586
Dec 29, 2024 07:39 PM
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
al_roethlisberger
Sep 9, 2015 09:14 PM
