Help changing daytime running light
Old May 2, 2019 | 05:15 PM
badicedog's Avatar
Default Help changing daytime running light
Anyone know how the heck to change the front upper daytime running lamp? It’s a T10 bulb, I removed the front headlight assembly and still couldn’t replace the bulb.
Old May 3, 2019 | 09:03 AM
TexasTraveler's Avatar
Not sure what your having an issue with? Once you pull the headlight assembly, you need to open up the the side domed cap to gain access to bulbs. Depending on what bulb your replacing you may need to remove other bulbs to get to the most inner bulb... Here is a link to when I did my led conversion, read through it an see if it helps you...
https://www.jaguarforums.com/forum/x...pgrade-195058/
Old May 3, 2019 | 09:44 AM
badicedog's Avatar
I've removed the bulbs to get access to the small T10 daytime running light. I just cant get access to it. I removed the side circular dust cover and also removed the whiole headlight assembly to no avail.
Old May 3, 2019 | 11:21 AM
peterv8's Avatar
I changed mine to LED with no problem.
Can't you reach in or is it like stuck when you try to remove it?
Old May 3, 2019 | 01:11 PM
Queen and Country's Avatar
I think I know the problem. It has a led bulb in it now that is big preventing access.
Old May 3, 2019 | 02:58 PM
Edit: These?
Old May 4, 2019 | 11:45 PM
badicedog's Avatar
Edit: These?
Not that one. Its nest to the cornering light, proximal to the engine.
Old May 5, 2019 | 10:51 AM
Cee Jay's Avatar
So, up inside where the green arrow is then? Dang, some pictures sure would help...
Old May 5, 2019 | 10:59 AM
sov211's Avatar
Let's clarify something here. The OP is not referring to the DRL bulb, but to the cornering light bulb in the Active light system (meaning the optional swivelling main light system). This cornering light only illuminates when the wheels are turned, and the other lights are on (the turn signal might also be involved in activating the cornering lamp...not certain, though), so this makes me wonder if there is in fact any problem with the bulb...or have I got this completely wrong and misunderstood? (Not at all impossible...still working on my first cup of coffee...).
Old May 5, 2019 | 01:06 PM
Cee Jay's Avatar
Yeah, this one.......... but I haven't had my housings out for a few years so I don't remember what the backside is like...
Old May 5, 2019 | 07:07 PM
badicedog's Avatar
[QUOTE=Cee Jay;2065831]Yeah, this one.......... but I haven't had my housings out for a few years so I don't remember what the backside is like...
QUOTE]
Bingo! that's the one
Old May 5, 2019 | 07:10 PM
badicedog's Avatar
Incorrect. I've changed the cornering light without problem. It's the little bugger next to it.
Old May 5, 2019 | 09:33 PM
sov211's Avatar
Yes, I can see that now.
Old May 6, 2019 | 01:53 AM
plc's Avatar
plc
according to the handbook the-- little bugger next to it-- is the side lamp and it is accessed through the the twist of large large domed cap
Old May 6, 2019 | 11:22 AM
badicedog's Avatar
I'm going to give a second attempt today.
Old May 6, 2019 | 04:09 PM
badicedog's Avatar
Success at last! Had to use a set of medical forceps to get a firm hold of the bulb receptacle. What a PITA. thanks for all your advice/help.
User 070620
Oct 14, 2019 05:17 AM
Doug Dooren
Feb 5, 2017 06:52 AM
stepdot
Aug 21, 2013 07:44 AM
