High pitch whine
Have a new higher pitch sound coming from the engine bay upon start up and with driving. I've read that typically it's one of 3 issues 1. Belt 2. Water pump (replaced last year) 3. Alternator. Anything you guys can think of that is known to affect our XK's? It's the same sound like when you have a radio on an a.m. station and you use an appliance nearby (older guys will get that one!)...
Hahaha! I should've included that I'm one of the older guys... and thank you!
My generator gave up the ghost just last year.
To be fair, the modern oem denso generator lasted 18 years and 180,000 kms. I’m impressed.
Still on the original water pump!
I think the 3rd tensioner… I don’t really remember as my memory is getting foggy.
Once you locate it and plan to change it, that will be the second item changed in that area. So while there, change a few other things! Idler pulley, tensioner, and especially the belt, for a cheap repair.
My vote is alternator...
That was mine..
replaced all other stuff plus motor mounts..
Understand there were some issues with aftermarket alternators working...
I went with a jaguar rebuilt one.....
so far so good
Appreciate the input! If it helps, Jaguar alternators in the era of our XK's, were manufactured by Denso or Bosch. The Duralast alternator I chose is manufactured by Denso. Hopefully, it works out!
03Styper1919
43
Aug 26, 2022 04:49 PM
Bankrupt2nite
Aug 5, 2021 04:42 AM
