How about electric cutout exhaust valves?
Old Apr 28, 2019 | 03:45 AM
peterv8's Avatar
Default How about electric cutout exhaust valves?
Anyone done it? Sounds like a nice option to be loud when I want! :-)
Old Apr 28, 2019 | 11:07 AM
Cee Jay's Avatar
Sure, it'd be loud, but a BAD loud. Class and decorum, my son.
Old Apr 28, 2019 | 11:25 AM
peterv8's Avatar
Yes, I thought of that and wonder if I could get a nicer sound by narrowing the pipe after the valve to maybe 20-30mm?
Old Apr 28, 2019 | 12:13 PM
Cee Jay's Avatar
I'd think it'd sound exactly like a leaky exhaust system, with the FUT-FUT-FUT sound.
Now, maybe by hooking up something like glass packs or something past the cut-out it would sound OK, and add another exit line for exhaust, like a quad instead of duals (no, quad tailpipes don't count).
I have something like this when I street drive my P/S Mustang II, I have removable caps on the straight exhaust which block the quick exit and sends it out the back through a couple small mufflers.
Old Apr 28, 2019 | 08:31 PM
steve_k_xk's Avatar
Peter drop the rear muffler and that will give you a good indication of how it will sound
Old Apr 29, 2019 | 12:33 AM
peterv8's Avatar
Sounds pretty cool!:-D
Old Apr 29, 2019 | 06:12 AM
jagtoes's Avatar
The only thing that concerns me here is the exhaust coming back into the cabin. If you split the quad tips so that the inside are routed from the cut outs and the outside is the full exhaust then you would dump the fumes out the rear and not under the car. My 2 cents. By the way my PAE is loud enough for me and the LEO's.
Old Apr 29, 2019 | 09:11 AM
8bit's Avatar
I changed the mid section on my 5.0 XKR recently. Couldn't resist the temptation to start the car and rev it a little while there was nothing attached after the catalysts - well the neighbours were all out so why not?
It was *brutal* loud. No way I could drive around that loud all the time, and that was just idling and a little revving in P so no actual load on the engine - can only imagine what it would have sounded like under real load at WOT.
Old Apr 29, 2019 | 10:45 AM
Ranchero50's Avatar
I too did it and there wasn't much tone difference from cat less down pipes to no muffler. It just got a little quieter the further from the engine. It was not a good sound...
Old May 30, 2019 | 12:24 PM
peterv8's Avatar
Point of no return!
As they came with remotes it was easy wiring!:-)
Had a local guy who welded them on, they came a little to far down then what I wanted cause I told the welder there was not much room above. After cutting the holes I should have put the exhaust back on and rechecked before welding. A little out of line they are but nobody see's that more then me and the MOT guy!:-D
Started the car with valves closed and opened them when idle and the tone became alot lower, sounded really nice. Revved it a little and it is loud.:-D
Will do some pipework later on when I've tested it a little more so the exhaust fumes don't get into the car.
Will do a video when the weather gets better. Should it be to loud and or bad tone I will just put a cover plate on and no harm done!:-)
Old May 30, 2019 | 12:29 PM
peterv8's Avatar
BTW, cause of the heat when welding the pipes moved sideways, about half an inch!
Thought I was cooked but after a cup of coffee and thinking I used a strap like this.....
and could get them aligned and on.:-)
Old May 30, 2019 | 02:41 PM
Ranchero50's Avatar
Yeah, the ratchet strap method will work OK. You'll need to go a little overcenter so they are the correct width once they relax. Hopefully they only need tweaked together and aren't twisted.
Old May 31, 2019 | 06:35 PM
MarkyUK's Avatar
I've no rear box and paramount straight through section as seen here:
https://www.ebay.co.uk/i/183074898783
Mine sounds exactly like the exhaust in the clip when the valves open, but ALL the time
Still no where near as loud as my X100 with straight through pipes and just two torpedo silencers behind the quads
Old Jun 9, 2019 | 11:50 AM
peterv8's Avatar
Finally got a video and I'm very happy with the sound. Was afraid it would be to loud but it sounds great! :-)
I noticed in the video my rear lights flicker but checked when I got home and they were fine so hope it's my camera as I've seen before that leds can flicker on cameras
Old Jun 9, 2019 | 03:14 PM
Cee Jay's Avatar
Frequency modulation of LEDs on video frame rates. Somewhat like how wheels and such appear to go backwards on TV and in movies.
Old Sep 12, 2023 | 08:47 PM
yovenim's Avatar
Banned
I have something like this when I street drive my P/S Mustang II exhaust cutout valve, I have removable caps on the straight exhaust which block the quick exit and sends it out the back through a couple small mufflers.
I'm curious if anyone is running an electric exhaust cutout. I'm trying to keep my car a little more subdued in the noise dept. I ordered a 3" stainless one and it was pretty big and I didn't see where it would fit. If you have one can you post pics and or tell me a brand that might fit.
Jeremy07XK
Feb 13, 2024 09:18 AM
general_piffle
Nov 27, 2021 05:36 PM
psb1013
Apr 25, 2016 10:32 AM
edra566
Aug 31, 2008 10:03 PM
dirtlawyer
Jun 29, 2007 01:23 PM
