Inop top
Old Jun 23, 2019 | 11:57 AM
jagjoe's Avatar
Default Inop top
I disconnected the battery to install the top remote kit. Upon completion the top would latch closed, and reopen for 6-8 " following other posts with this problem, I manually stowed the top. This had no effect on the ability of the top to do anything. I manually raised the top and disconnected the battery, waited 15 or so minutes, reconnected the battery and tried the top again, nothing. I have tried with the top up and down, disconnected the battery several times all for nothing. The battery is fully charged and I had no problems till I disconnected the battery after the installation to reset the top control.
Any ideas? I am out of them.
Old Jun 23, 2019 | 12:39 PM
Cee Jay's Avatar
Did you first reset the front window travel before you tried opening/closing the roof?
Old Jun 23, 2019 | 01:42 PM
jagjoe's Avatar
I reset them the first time, does it have to be done every disconnect?
Old Jun 23, 2019 | 01:55 PM
jagjoe's Avatar
Reset the windows again, stowed the top, still nothing.
Old Jun 23, 2019 | 04:13 PM
kj07xk's Avatar
You did re-tighten the valve on the motor hydraulics after manually moving the top, correct?
Also try holding the top open (or close) button on the roof panel for a really really long time (greater than an actual minute) to see if the top re-engages.
Old Jun 23, 2019 | 05:02 PM
Cee Jay's Avatar
Way back when I had a top problem, the over-the-window hinge part misaligned itself. I had to re-crank the in-the-roof hand crank thing in and out again to make it realign.
Old Jun 23, 2019 | 10:14 PM
Stuart S's Avatar
Since you had a problem while installing WhiteXKR's remote top kit, you should call or PM Steve, explain what happened, and ask him to call you on your cell. He's a great guy and will be glad to help.
Old Jun 23, 2019 | 10:32 PM
WhiteXKR's Avatar
Do the front window reset again. Then try to operate the top with the console the first time after the window reset, not the remote.
If it does not work repeat this sequence again. Keep repeating up to half a dozen times or so until the problem is solved. The window reset on the XK/XKR does not always 'take' and sometimes needs to be repeated quite a few times.
After all this if it still is not working properly contact me as suggested for further help.
-Steve
Old Jun 26, 2019 | 11:05 AM
jagjoe's Avatar
Default Top inop
I recycled the windows 8 times, still the top does not respond. The top is in the stowed position, when it was in the up position it still did not operate.
Any ideas will be appreciated.
Thanks Joe
Old Jun 26, 2019 | 12:22 PM
Cee Jay's Avatar
Sort of sounds like the pump is still in BYPASS mode. Are you sure you reengaged the pump completely after you moved the top manually?
Old Jun 26, 2019 | 01:49 PM
jagjoe's Avatar
Yes I did, all suggestions are greatly appreciated and I will try anything.
Joe
Old Jun 26, 2019 | 01:57 PM
jagtoes's Avatar
Joe
Contact WhiteXKR and he should walk you through this. maybe a fuse or an installation issue. It will get resolved.
Old Jun 26, 2019 | 09:40 PM
WhiteXKR's Avatar
Go to my contact page and lets set up a mutually convenient time to do a phone call with you at the vehicle: Contact Us - TheJagWrangler
It is important to me that all of my customers successfully install the kit.
Old Jun 27, 2019 | 12:14 PM
jagjoe's Avatar
I opened it back up , and checked all the wiring, all seemed to be good.
Joe
Old Jun 27, 2019 | 03:40 PM
jagjoe's Avatar
Steve came thru. I switched off the one touch, and the top came to life. Ran it thru a couple of cycles then switched the one touch back on and it all works. Thanks Steve.
Joe
Old Aug 2, 2024 | 10:20 AM
MJSJAG's Avatar
How do you turn off the "one touch"?
Old Aug 2, 2024 | 11:17 AM
kj07xk's Avatar
There’s a switch on the side of the controller box.
mitch.thompson
Jan 19, 2011 02:13 PM
gdcont
Jan 17, 2011 07:51 PM
Merrill
Sep 3, 2010 09:08 PM
satrianirocks
Oct 28, 2009 09:09 AM
whiteSTR
Sep 2, 2009 04:42 PM
