Instructions for removing door panels
Old Mar 19, 2014 | 04:02 PM
jahummer's Avatar
Default Instructions for removing door panels
Going to remove the door panels to upgrade the seat switch packs tomorrow. Anyone have a copy of the section from the shop manual handy? Thank you very much!
Old Mar 19, 2014 | 06:28 PM
X150 - Front Door Trim Panel (76.34.01):
X150 - Door Trim Panel.pdf
Old Mar 19, 2014 | 10:45 PM
guy's Avatar
guy
Why upgrade the switch packs?
Old Mar 20, 2014 | 02:27 PM
jahummer's Avatar
The 07-09 US was dull. Jag updated them in 2010-2011. Here is a before and after! Especially now that I have replaced the interior wood with piano black.
Attached Thumbnails Instructions for removing door panels-photo-1.jpg   Instructions for removing door panels-photo-2.jpg
Old Mar 20, 2014 | 06:29 PM
u102768's Avatar
Did they end up being a straight swap?
Old Mar 20, 2014 | 07:17 PM
jahummer's Avatar
They did indeed, about 15 minutes apiece. Very pleased with the results for little $$$. I had considered the current 2012-2014 version which is all piano black but decided this version has the best contrast & class, flowing nicely with the other chrome, champagne & piano finishes in my car.
Old Mar 21, 2014 | 03:25 PM
sov211's Avatar
I might also do this (been on my mind for a while) - any tricks or danger points? Do you have to disconnect the door handle cables to do this?
Old Mar 21, 2014 | 03:55 PM
jahummer's Avatar
It is easy and straight forward. No surprises, although I have taken Jaguar interiors apart before. I highly recommend you use nylon non marring trim removal tools to assist.
Unless you have an extra set of hands to help you hold the panel while you swap the switchpack, you will need to disconnect the door release cable and door wire harness, both very easy to do. Like any job the right tools and proper prep will make your work easier.
If you need help let me know.
Old Mar 22, 2014 | 11:39 AM
sov211's Avatar
Thanks for this clarification. I have restored many Jaguars so I don't anticipate a problem - just preferring not to encounter any surprises!
My 07 XK ("luxury") interior has been upgraded at this point to equal that of the 2008 model (window switch pack and walnut inserts, steering column switches with chrome rings, chrome radio knob); the finishing touches (bringing it to 2009) would be the seat switch pack and perhaps the tweeter chrome rings, but I am not sure about the latter - a bit visually distracting, I think. We'll see. It used to be that owning a Jaguar meant spending all sorts of money on maintenance. Now that they are, in that respect alone, boring to own - because nothing seems to go wrong (and I have owned many of them, so this comment is not based on a single example) - funds and time are freed for entirely unnecessary cosmetic upgrades (authentic Jaguar XK options, not aftermarket) - like the anodysed stainless trim piece for the luggage compartment, and that lovely, heavy overlay carpet for the luggage area. Fun! These cars are jewels. Yesterday I saw a white Aston Martin DB9 and as it passed by it occurred to me that the XK is more beautiful, and more "out together" in detail and outline; I much prefer the interior of the XK over the DB9 as well.
Old Mar 22, 2014 | 11:41 AM
sov211's Avatar
With regard to the XK vs the Aston, I meant "put together". "Out together" sounds like fun, but it isn't what I intended to say!
Old Mar 27, 2014 | 10:32 AM
chromedragon's Avatar
Uhm, I see 6 cars listed. not including one under your name. What car are you talking about?
Old Mar 27, 2014 | 07:09 PM
sov211's Avatar
His instructions regarding the seat switch pack relate to his XK - see the photos. Or does your question relate to something else entirely?
Old Mar 28, 2014 | 06:55 AM
Ah, I read the first entry. I needed to look into the rest of the entries to find out.
Old Mar 31, 2014 | 08:58 PM
Gray XK's Avatar
Looks great. How much were the switch packs and where did you get them? I've been thinking about doing the same thing but have never gotten around to it
Old Apr 1, 2014 | 02:45 PM
jahummer's Avatar
The part numbers are C2P17343 & C2P17341, I bought them at a Jag dealer. You can do the same or buy them online. If you do a google search, several sites will come up.
Old Apr 1, 2014 | 08:11 PM
Gray XK's Avatar
Perfect, thanks!
Old Apr 7, 2014 | 12:09 PM
hoya_loya's Avatar
Nice.upgrade!
Old Apr 3, 2023 | 12:55 AM
Geirullenes's Avatar
Hi Guy :-). I love your new switch pack. Can you advice me where to search for this item. Thanks. Rgd Geir
Old Apr 3, 2023 | 01:20 AM
jahummer's Avatar
Old Apr 3, 2023 | 02:46 AM
Welcome to the forums Geir,
As you have posted directly in the Model forum without first posting an Intro, please read the guidance for new members ( https://www.jaguarforums.com/forum/n...ned-up-241802/ ) which answers many of the most frequent questions about getting started.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
GordoCatCar
Jan 2, 2017 01:10 PM
obwoodie
Sep 3, 2015 07:45 PM
